E3 spark plugs #2375250
09/22/17 11:10 PM
09/22/17 11:10 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Been running some R43XLS's in my warmed over 360. Gonna try some E3.46's ( direct cross ). Anyone else running E3's?
Fastest 300
Re: E3 spark plugs [Re: Crizila] #2375382
09/23/17 10:57 AM
09/23/17 10:57 AM
moparx Offline
moparx  Offline
will be interested in seeing your results. i always thought those were just a "trick of the week" gimmick, so i never coughed up the bux to try a set. please don't think for one second i'm slamming you john ! it would be neat to do an A-B-A test on those if possible. please post your results. i will freely admit i am a "poopyhead" if you have success, right here before GOD and country !
beer
Re: E3 spark plugs [Re: Crizila] #2375389
09/23/17 11:09 AM
09/23/17 11:09 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yeah, i'v been thinking about maybe giving those a try once I figure out what my 511 wants for heat range.
Re: E3 spark plugs [Re: mopar dave] #2375408
09/23/17 11:48 AM
09/23/17 11:48 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Re E3 plugs...
1. Some years back David Vizard did an article on them where he talked about the design and did a dyno test vs a comparable Autolite Racing plug (which he said at the time was the best performing racing plug he'd tested). It was a NASCAR Street Stock class engine making about 400 HP and they both made within 1/2 HP of each other. I searched for this article online, but haven't been able to find it.
2. Google "AETC 2015 E3" and you can get the overview of a presentation about them.
I use Autolite Racing plugs and don't feel any need to change. However, I did find some of the above interesting.
Re: E3 spark plugs [Re: mopar dave] #2375418
09/23/17 12:15 PM
09/23/17 12:15 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I will post results, but I warn you, they will be "seat of the pants". Plugs will be going in to a street build 360 ( .030 over 9.7:1, Hughes 1523AL, 2.02 pocket ported J heads, Edelbrock performer & 650 AVS. Petronix dist./ coil with Chrysler orange box ) where my R43XLS's were living quite happily. Just been curious about them and O'Reily's had them on sale.
Fastest 300
Re: E3 spark plugs [Re: BradH] #2375422
09/23/17 12:31 PM
09/23/17 12:31 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Originally Posted By BradH
Re E3 plugs...
Doubt my 72 year old saggidy-assed butt will be able to detect a 1/2 HP difference. laugh Maybe on the drivability side, although that isn't an existing problem either with this mild build. At least if Capps or Schumacher asks me "What plug's are you running" I can say - same as you! grin
Fastest 300
Re: E3 spark plugs [Re: BradH] #2375424
09/23/17 12:34 PM
09/23/17 12:34 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I like reading davids article. Interesting stuff.
Re: E3 spark plugs [Re: Crizila] #2375427
09/23/17 12:41 PM
09/23/17 12:41 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I have had 4 different customers that wanted to see if the E3 plugs made more power. So at the end of the dyno session we put them in and they made less then 1 hp difference. We even adjusted one of the engines up and down 1 degree to see if it made a difference. But i am sure that the owners cars were faster due to the loss of weight inside their wallet.
Joe
Without Data, you’re just another guy with an opinion.
Re: E3 spark plugs [Re: mopar dave] #2375429
09/23/17 12:45 PM
09/23/17 12:45 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
It's been kinda fun watching guys over the years getting sucked into every little trick in the book over the years. Around 42 years ago I asked an old time mopar engine builder is question about an issue with the 340 in my duster back in my street racing days. When I told him what my car was doing he looked at me and said, You are using Champion spark plugs aren't you? I told him I was and he told me to throw them away and put a set of Auto-lite plugs in there and the issue would go away. I put a set in that day and have been running them ever since. Zero complaints
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: E3 spark plugs [Re: Crizila] #2375435
09/23/17 12:55 PM
09/23/17 12:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
25 years ago or so I was building 318-2bbl motors for a local oval track series.
I generally prefer to use NGK plugs, and the normal plug for those was a BPR6ES.
I don't remember why I tried them, but the BPR6ET is the same plug with three ground straps and the electrode in the center of them.
No big gains, but they seemed to consistently add a number or two over the std plugs.
They were basically the same price...... So we stuck with them.
Re: E3 spark plugs [Re: fast68plymouth] #2375507
09/23/17 02:57 PM
09/23/17 02:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
Piston engine aircraft engines have used multiple ground strap spark plugs for years, they have two plugs per cylinder and two magnetos also.
They would last about 500 hours in my 260 HP Lycoming 540 C.I. opposed flat six cylinder air cool engine.
They call for .016 air gap on both sides and I would have to gap them again after around one hundred hours due to wear on the center ground electrode and a little wear on the plug straps work The instructions called for replacing them after the center electrode started looking a lot like a football instead of a baseball, which they would get like shruggy
Nothing magical or better about them is my impression, not cheap though either shruggy
Seems like several years back there was another attempt by a different company to market multiple ground strap spark plugs which never gain popularity or a large enough use to keep the company in business work shruggy
Re: E3 spark plugs [Re: sr4440] #2375535
09/23/17 03:53 PM
09/23/17 03:53 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Joe
laugh laugh laugh Guess that would be me. "The older I get, the faster I went".
Fastest 300
Re: E3 spark plugs [Re: Crizila] #2375611
09/23/17 07:14 PM
09/23/17 07:14 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
50 years ago JC WHITNEY was selling that type of plug. They were a cure all for every problem your engine had. LOL
Re: E3 spark plugs [Re: Crizila] #2375623
09/23/17 07:45 PM
09/23/17 07:45 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Where does this leave plug-indexing?
I'm seeing more ground 'posts' blocking flame.
Only advance I can see right now is this plug will last longer because there's more ground area the spark can 'land'.
Re: E3 spark plugs [Re: Crizila] #2376281
09/25/17 10:20 AM
09/25/17 10:20 AM
an8sec70cuda Offline
LOL, snake oil. Maybe try some Split Fires next?
As long as you have the right heat range and reach, all it has to do is make a spark.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: E3 spark plugs [Re: Crizila] #2376325
09/25/17 11:28 AM
09/25/17 11:28 AM
crlush Offline
crlush  Offline
I remember trying splitfire plugs many years ago and all i got was a lighter wallet out of the deal. The only bigger scam in my book is a cold air intake/filter on a stock car.
Re: E3 spark plugs [Re: crlush] #2376335
09/25/17 11:41 AM
09/25/17 11:41 AM
moparx Offline
moparx  Offline
one of my favorites was the "hurricane" intake propeller thingy ! biggrin
beer
Re: E3 spark plugs [Re: moparx] #2376356
09/25/17 11:59 AM
09/25/17 11:59 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I love this web sight! Gives me a "procrastination" break from this. bondo
Fastest 300
Re: E3 spark plugs [Re: crlush] #2376447
09/25/17 01:57 PM
09/25/17 01:57 PM
The Netherlands
The Netherlands
Originally Posted By crlush
... The only bigger scam in my book is a cold air intake/filter on a stock car.
You mean like every carmaker is doing these days?
Re: E3 spark plugs [Re: BigBlockMopar] #2376458
09/25/17 02:18 PM
09/25/17 02:18 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
You mean like every carmaker is doing these days?c
Yep, cold air is not a scam.
