Page 3 of 4 1 2 3 4
Re: Projected tip plugs more prone to detonation? [Re: rdrnr33] #2374144
09/20/17 09:29 PM
09/20/17 09:29 PM
Washington
madscientist Offline
Washington
Originally Posted By rdrnr33
So should I cut back on the octane booster or just see how the RN9Ys look after some road time?
I prefer the C series but if the 13/16 hex isn't a nightmare than I it's ok.
Don't know your combo but I run a 12 Champion on 11:1 pump gas.
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374197
09/20/17 11:02 PM
09/20/17 11:02 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Are projected tip plugs more prone to detonation, as compared to the equivalent non-projected tip plug?
All else being equal, Yes!
OK, this is the first voice with a clear contrary position. Can you share your thoughts on this? Do you think the projected tip is hotter than a standard plug and can act like a hot spot (that was my original thought)?
No matter what the heat range numbers say for a particular plug ( or comparing different brands of plugs), the farther the porcelain and tip is from the plug housing, the hotter it is going to run.
That was sort of what I was thinking but then I realized I didn't know the details of the heat rating of a plug. Does it represent the temperature at the electrode? If so, then equivalent plugs would have the same temperature (although it would be located in a different spot in the chamber). If the rating represents the temperature at the porcelain at the body of the plug (where the actual control point is) then the tips would clearly be different temperatures. Any one know what portion of the plug the heat rating is based on?
Re: Projected tip plugs more prone to detonation? [Re: Cab_Burge] #2374210
09/20/17 11:19 PM
09/20/17 11:19 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Originally Posted By Cab_Burge
I know of another guy in SO CA that worked in a knock lab also, he lead me to use the projected tip spark plugs in iron headed B and RB motors as well as all of the Mopar hemi motors for drag racing and street use work
Same information, different conclusions confused work
I had low compression(true 8.5 to 1) pump gas 350 Chevy boat motor that pinged, knocked, on regular pump gas with a Champion J12Y and quit knocking with a Champion J11Y work
I worked in service stations a long time ago before they became gas stations only and I have seen many stock motors that needed the spark plugs heat range changed for the driver work
Around town only grandma drive differently than there hot rodder grand kids did shruggy
Colder is always safer than a tiny bit to hot when it comes to gasoline and different driving conditions and fuel used work
I agree colder is always safer when balanced against the negative of too cold. Can you explain more on the "same information, different conclusions"? Are you indicated that your source also felt projected tip were more prone to detonation but had some other benefit that outweighed it? Or that the standard plug was more prone?
I guess it comes down to a balance of many factors, like most things. I am still not sure what type of plug to get, but at least they are not too expensive in the grand scheme!
Re: Projected tip plugs more prone to detonation? [Re: Cab_Burge] #2374282
09/21/17 12:45 AM
09/21/17 12:45 AM
Az
Crizila Offline
Crizila  Offline
Az
Juat sayin Hi Thumper. To Cab; I'm not sayin don't run extended core plugs. Just sayin they will run hotter, all else being equal. Ran them in my wedge motors all the time back in the day. They helped to solve a lot of problems such as poor intake runner and combustion chamber design, poor fuel distribution, weak ignitions, etc. A lot of them lived due to high octane leaded fuel. If you can run them and don't end up with the attached pic, by all means, run them. BTY, the pic is the result of running a way wrong heat range plug - and running a little lean.
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374288
09/21/17 12:50 AM
09/21/17 12:50 AM
Az
Crizila Offline
Crizila  Offline
Az
Same piston exposed to detonation. BTW, never heard it until the damage was done.
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374324
09/21/17 01:44 AM
09/21/17 01:44 AM
You had the same experience that a lot of racers and hot rodders have, they don't hear it until the motor quits or starts smoking whiney
I learned to look at the plugs frequently until I knew the tune up was safe up
On my stock 415 HP M.W. on the old 100+ octane high lead pump fuel in 1971 to 1973, it liked the stock J11Y, not the J10y or the hotter J12Y spark plugs. I could hear the difference in idling right away, I could see the differences in on the plugs with one full WOT blast down the street work
As far as heat on the plug tip the center porclyn determines what the tip temperature will be, retracted or projected shruggy
More porclyn around the center electrode less heat transfer work
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2374406
09/21/17 11:03 AM
09/21/17 11:03 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just to interject something I know doesn't answer the question. The most detonation resistant plug I've seen with in car, and on dyno experience is an NGK 6061-10. That is against autolite AR series, and champions true race series plugs.
Can't copy the pic, but look at the electrode, and strap arrangement in the link.
http://static.summitracing.com/global/images/prod/large/NGK-5962_w.jpg
Re: Projected tip plugs more prone to detonation? [Re: Cab_Burge] #2374447
09/21/17 12:11 PM
09/21/17 12:11 PM
Az
Crizila Offline
Crizila  Offline
Az
Plug electrode heat build up transfers through the porcelain to the plug main body. The farther it is from the main body, the less heat transfer there will be and the hotter the electrode will run. What I was always taught. By 73 high lead content fuel was being phased out as it was killimg convertors - and us of course. Attached is a comparison of 3 plugs that I have run in the past in my SB. Right 2 are NGK's. Left is a Champ. Right plug is by far the coldest (-9) which I run in my blower motor. Left 2 I have run in NA motors and they would not survive in my blower motor. All worked well in the proper environment.
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374457
09/21/17 12:37 PM
09/21/17 12:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hi back at ya and are these your blower pistons.......
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2374533
09/21/17 02:29 PM
09/21/17 02:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes. I'm a slow learner. frown
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374534
09/21/17 02:32 PM
09/21/17 02:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not apples to apples in a power adder situation and I've been using projected tips forever w/zreo issues as long as the carb/timing are where they need to be............. thumbs
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2374553
09/21/17 02:51 PM
09/21/17 02:51 PM
Az
Crizila Offline
Crizila  Offline
Az
True. Can't remember for sure, but with the boost I was running the static CR figured out to be around 17 -18:1. Projected tip plugs don't live there.
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374566
09/21/17 03:24 PM
09/21/17 03:24 PM
I was told by many E85 users to use retracted gap plugs in my E 85 bracket motor, I do up
As far as blower motors I was told the same thing on not using projected gap plugs in them, I have found out since then that on blown gas hemi motor the projected gap plugs use under 12.0 lbs. of boost live a long time if the fuel and timing are close to correct shruggy
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374589
09/21/17 04:14 PM
09/21/17 04:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, I did a pair of carbs for a blown 588 BB Chevy in a 25" Eliminator boat and they need the non projected plugs and a bit colder accordingly...........fires right up w/the bump of the key and he lifted at 115 mph at only 5200 rpm stating "It's too fing fast" but would fall on it's face prior...........Power adder stuff is in it's own tuning world imo............ beer
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2374730
09/21/17 09:03 PM
09/21/17 09:03 PM
crabman173
crabman173
Smokey Yunick invented the projected tip plug--it has been std equip for 40-50 years now?? They are supposed to idle cleaner and better
I have been a hot rod nut and engine guy all my life --I have never had a better plug or better plug company than NGK--quality is unsurpassed--tech line answers phone on first rings and if you give correct info--all ya need is correct compression ratio--fuel type--and the proper thread engagement stuff like always They will put you ON THE MONEY first time if you give correct info Then you order off Ebay with free shipping and no sales tax and get the best for less--I tell this tale again and again but folks fight it and always have other opinions---
Yes Autolite race plugs and Champion race series are good plugs but tech is almost non-existent and price is just stupid compared to NGK on Egay
Just try call NGK tech which you can Google
These are the best quality plugs available Japanese made --superior quality--Amazing tech support--and best price of all the quality units available
Quit fighting City Hall and try em will ya???
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2374794
09/21/17 11:25 PM
09/21/17 11:25 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
I have not been sure what part of plug is used for the heat rating. Found this link this evening:
https://www.ngksparkplugs.com/about-ngk/tech-talk/spark-plug-basics
The description that NGK provides indicates to me that the heat rating does reflect the tip/electrode end of the plug. That should mean that a projected and non-projected tip plug of the same heat rating would have approximately the same temperature at the electrode. That temperature point is placed in a different location in the combustion chamber though.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2374861
09/22/17 01:32 AM
09/22/17 01:32 AM
Now your learning from a good source up bow
Re: Projected tip plugs more prone to detonation? [Re: ] #2375244
09/22/17 10:52 PM
09/22/17 10:52 PM
Az
Crizila Offline
Crizila  Offline
Az
Totally agree on the NGK thing up
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2375307
09/23/17 01:36 AM
09/23/17 01:36 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I'd like to see some ACTUAL results from using different brands of the same heat range plugs. I would guess that there wouldn't be much difference to measure. I would have to say yes to the original question. At some point sharp edges and projectile tips will retain more heat in the combustion chamber. Common sense.
Re: Projected tip plugs more prone to detonation? [Re: Dave Hall] #2375426
09/23/17 12:39 PM
09/23/17 12:39 PM
Az
Crizila Offline
Crizila  Offline
Az
up - as long as you don't read anything else in to the question - which is NOT SOP for this site - which is ok.
Fastest 300
Page 3 of 4 1 2 3 4
