Re: Gen III Hemi parts
[Re: LSP]
#2374909
09/22/17 10:02 AM
09/22/17 10:02 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
FWIW my list
1) Solid Link Bar lifters, I'm tired of modifying blocks and bottom of heads and head gaskets to get Brand X lifters to work. Key way Lifters work, but the expense for the mid level performance guy is just out of reach. From Roller tip to top of link bar needs to be 3.5 inches to clear the block, 2) 1.8 rockers, adjustable rockers would be great. 3) Intake ..but this is a hard one, Drag Pak is too tall for most people, OCP is too Dual plane, and Arrow is down on power. Mod man just plan ole sux(unless your going for the cool factor). Something like the Holley LS Viper intake, some of the real crap quality ones can be had on E-bay for about $180....don't laugh at them they run well. I'm working on a Cross ram similar to the Gen II Viper.... I'm done with my wish list for now. Thanks
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Dragula]
#2397690
11/03/17 03:57 AM
11/03/17 03:57 AM
Posts: 6,148 Melbourne , Australia
LA360
Rocker hold downs...Rocker arms.....Valve covers with only one spark plug hole for the guys that put the timing cover shorty distributor conversions on, for class racing.
Oil Filter relocation kit.....
I made a oil filter relocation kit for a guy a while back, I looked at revising it and making more again at some stage. I didn't really think there would be enough interest there for them.
Alan Jones
[Re: fbs63]
#2397740
11/03/17 09:58 AM
11/03/17 09:58 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
A cam adapter to use a non-vvt cam in a vvt block with the non-vvt timing set. I know there is one available but the price is ridiculous for what it is. I second this^^ along with crank spacer for timing gear for early crank in VVT engine.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2398303
11/04/17 09:04 AM
11/04/17 09:04 AM
ric3xrt
Trumbauersville PA
A cam adapter to use a non-vvt cam in a vvt block with the non-vvt timing set. I know there is one available but the price is ridiculous for what it is. I second this^^ along with crank spacer for timing gear for early crank in VVT engine. The VVT crank spacer is out there , Molnar has them.
