Re: '76 3/4 ton, light versus heavy.
[Re: bboogieart]
#2376507
09/25/17 03:18 PM
09/25/17 03:18 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
My W300 has 5/8" studs. Not sure about the 3/4 ton trucks? Was the 300 a 4 wheel drive, 1 ton truck? Yes. Mine is a 1 ton Dump. Full Time 4x4.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 19swinger70]
#2376517
09/25/17 03:27 PM
09/25/17 03:27 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
My W300 has 5/8" studs. Not sure about the 3/4 ton trucks? Was the 300 a 4 wheel drive, 1 ton truck? Yes. Mine is a 1 ton Dump. Full Time 4x4. Sounds like a neat rig.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2376771
09/25/17 09:48 PM
09/25/17 09:48 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
You guys ever heard of a "Camper 9000" ? I had a 1974 truck with fender emblems reading Camper 9000. It had the fat 5/8 lugs, super heavy Dana 60 or 70, not sure which. The rear drum brakes were immense and hard to find used.
[Re: ruderunner]
#2376934
09/26/17 01:59 AM
09/26/17 01:59 AM
Posts: 259 n.c.
geo.
n.c.
Think you should be able to swap studs. Not sure the whole hub and rotor combo swaps.
As for model designation,. D is 2wd,. W is 4wd. 100 is light half ton, 150 is heavy half, these came about in the mid 70's due to emission regs. 200 is 3/4 and 300 is 1ton.
The 9500 tossed out above is referring to gvw. I remember reading that the 150 designation was what allowed the '78 Little Red to have a higher GVWR and therefore escape the catalytic converter requirement. I wonder if all 150s in '78 escaped the converter requirement? Good luck on the stud search!
[Re: bboogieart]
#2376966
09/26/17 07:47 AM
09/26/17 07:47 AM
Posts: 5,829 ohio
ruderunner
ohio
Dodge wasn't the only company to offer higher gvw half tons in order to get away from catalytic converter on the trucks.
Ford offered the F-150 starting in 76, Ih offered Scouts with the XLc package, GMC had I think the Big10 package and Chevy just called them heavy half.
Angry white pureblood male
[Re: bboogieart]
#2377002
09/26/17 10:29 AM
09/26/17 10:29 AM
19swinger70
Richmond, Indiana
My W300 has 5/8" studs. Not sure about the 3/4 ton trucks? Was the 300 a 4 wheel drive, 1 ton truck? Yes. Mine is a 1 ton Dump. Full Time 4x4. Sounds like a neat rig. It is a handy blunt object to have around!
