What kind of numbers should I expect out of this setup?
#2374212
09/20/17 11:26 PM
09/20/17 11:26 PM
Posts: 79 KY
95Kota408
KY
Just curious what kind of numbers I should expect out of this build. Still don't have a car to put it in yet. Looking for a roller Challenger project I think. Note: Right column on flow sheet is the final port work numbers.
408 Block was honed with Torque Plates Align honed Square Decked
Scat Forged Crank Scat Forged I Beam Rods Auto Tec Forged Pistons Eddie Heads Fully Ported 2.02 Ferrea Competition Plus intake valves 5/16" stem 1.60 Ferrea Competition Plus exhaust valves 5/16" stem C.H.E. Precision valve guides T&D Shaft Mount Roller Rockers 1.7 Crower Lifters Innovators West Damper Moroso Oil Pan Indy Mod Man Intake FI Tech 2x4 throttle body injection or 6 Pack? ( Haven't decided yet)
Cam specs are:
242/250 112 LSA Lift IN/EX .621 .621
Re: What kind of numbers should I expect out of this setup?
[Re: Spaceman Spiff]
#2374364
09/21/17 08:56 AM
09/21/17 08:56 AM
Posts: 79 KY
95Kota408
KY
10:1 compression ratio with pump gas
[Re: 95Kota408]
#2374391
09/21/17 10:35 AM
09/21/17 10:35 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
[Re: J_BODY]
#2374393
09/21/17 10:41 AM
09/21/17 10:41 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You can't even start to give an ET guess with the info you gave. Without knowing the car weight, gearing, converter stall, header sizing, and several other important items. Hell we saw .40 in just moving from one race converter to another.
[Re: 95Kota408]
#2374395
09/21/17 10:49 AM
09/21/17 10:49 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
3300 pound car with hook and sorted out. 10.90's- 11.00's..... maybe
Tiny, wide cam. Dont think that cam will do you absolutely any good if Et is the goal
[Re: mopar dave]
#2374554
09/21/17 02:54 PM
09/21/17 02:54 PM
B3422W5
Portage,michigan
112 lobe sep might be a pooch off the line unless your running a high stall or sprayin it. I once ran 112 scott brown cam with a 3500 stall n/a 408 and it was a real pooch from a dead stop. Had the exact same result. The OP only has a 10 to 1 motor, wide lsa will kill it out of the gate.
