Which Wix filter to run?
#2373851
09/20/17 12:17 PM
09/20/17 12:17 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I have been running the FL1-HPs on my Plymouth for awhile and have purchased Wix filters because of cost,I have 51515 and 51515R filters. I know the microns and flow rates are different between the two, but I'm looking for some input. My car usually gets an oil change once a year. I doubt I put more than 300 street miles on it and maybe 30-40 passes down the track a year.
72 Plymouth Roadrunner 11.08@123.25
Re: Which Wix filter to run?
[Re: Roughbird72]
#2373880
09/20/17 01:33 PM
09/20/17 01:33 PM
RapidRobert
I'd go with the 51515 (lowest microns-20 iirc) for the best filtering.
[Re: Roughbird72]
#2373887
09/20/17 01:47 PM
09/20/17 01:47 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I've always used the normal 51515.
[Re: Roughbird72]
#2373912
09/20/17 02:58 PM
09/20/17 02:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have been running the FL1-HPs on my Plymouth for awhile and have purchased Wix filters because of cost,I have 51515 and 51515R filters. I know the microns and flow rates are different between the two, but I'm looking for some input. My car usually gets an oil change once a year. I doubt I put more than 300 street miles on it and maybe 30-40 passes down the track a year. The 51515R is the racing filter and it flows more but doent have the filtration of the 51515 which I use all the time now
[Re: Roughbird72]
#2373944
09/20/17 03:52 PM
09/20/17 03:52 PM
Roughbird72
Thanks Guys! The 51515 has a burst pressure of 290#, so cold start ups at 90# shouldn't be an issue.
[Re: Roughbird72]
#2374422
09/21/17 11:33 AM
09/21/17 11:33 AM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Napa gold 1515 is also a wix. Been using those on the roadrunner.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: MadMopars]
#2374429
09/21/17 11:40 AM
09/21/17 11:40 AM
Roughbird72
Although I have yet to take advantage of it, I just came across the Wix filter discount thread linked below. Since you posted up a Wix discussion, I figured I would bring it up for other members like myself who may be unaware of the savings potential. Certainly worth taking a look at if you already haven't. -Trent WIX Discount for Moparts Members - Link Rock Auto $4.06
[Re: Roughbird72]
#2374432
09/21/17 11:46 AM
09/21/17 11:46 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I've had at least 4 bad wix filters in the past few years... so check your oil pressure when you put one on and be ready to turn the engine off fast.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2374459
09/21/17 12:40 PM
09/21/17 12:40 PM
Roughbird72
I've had at least 4 bad wix filters in the past few years... so check your oil pressure when you put one on and be ready to turn the engine off fast. I always crank til I get oil pressure,before turning on the fuel.
[Re: Roughbird72]
#2374469
09/21/17 01:01 PM
09/21/17 01:01 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
For a street motor where reliability is excelent due to the parts used, i would go 51515. Race, 51515r to catch debris should you have a failure and metal floting around. With the higher flowing media, the r filter doesn't bypass the oil nearly as quickly, lncreasing the chance to catch the junk.
[Re: gregsdart]
#2374957
09/22/17 12:09 PM
09/22/17 12:09 PM
Posts: 19,591 north of coder
moparx
of the 30+ years i have ran wix filters, i have had several where the threads were bad. i have a 3/4-16 "form" tap which, as the name suggests, "roll forms" the threads with no metal removal. those i have fixed easily, and i have a plated 3/4-16 bolt i use to check the threads on every filter i use because i fill each filter before installation. the only other defect i have come across using these filters is once in a while, for whatever reason, the filter comes without a gasket. those, i return. the 51515 fits my whole fleet, including my FWD minivan with the 3.3 engine, so i buy these by the case.
