99 Ram 1500 2wd trans shot ??? #2373373
09/19/17 03:58 PM
09/19/17 03:58 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
99 Dodge Ram 1500 2wd 5.2l.
Drove fine, parked it overnight, next day it won't move in any gear. Checked fluid - level is fine. Looks clean, no smell. No leaks, no wires off, all linkage intact.
Any ideas ??
Re: 99 Ram 1500 2wd trans shot ??? [Re: Stanton] #2373422
09/19/17 05:22 PM
09/19/17 05:22 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Check for codes.
Get paper and pencil to mark down flashes and pauses of Check Engine Light.
Cycle ignition key On OFF On Off then leave in On
Watch and count groups of light flashes and pauses
or see if digital odometer readout changes from miles to a CEL code readout.
1999 46RE auto trans has Variable Fluid feature controlled by PCM computer that should be a suspect.
Check fuses and resets
