Innovate MTX-AL Air Fuel ratio Gauge experiences?
#2371380
09/15/17 07:44 PM
09/15/17 07:44 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Has anyone tried this? It looks interesting. I now have a goPro, so I can video the gauges. If this thing is accurate, that could be a valuable tuning tool. A/F gauge
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Innovate MTX-AL Air Fuel ratio Gauge experiences?
[Re: Hemi_Joel]
#2371381
09/15/17 07:46 PM
09/15/17 07:46 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I like the digital one better. #3918
[Re: mopar dave]
#2371429
09/15/17 09:27 PM
09/15/17 09:27 PM
CSK
Pattison Texas
I like it. I have the mtx-l digital and sometimes it sweeps thru the numbers so fast cant get a positive read. With the needle i think you might get a better idea if its sweeping quickly. yes the digital reads fast, thats the point, I can see a misfire on my gauge.
[Re: Hemi_Joel]
#2371620
09/16/17 09:26 AM
09/16/17 09:26 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I have been happy with innovate's products. If this is something for the coupe I would recommend two of them. I was really surprised how different the two banks on my car are when I added a second sensor. With 8 carbs you can dial that in pretty good if you have the info.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2371878
09/16/17 09:11 PM
09/16/17 09:11 PM
Posts: 31,077 Oregon
AndyF
I have been happy with innovate's products. If this is something for the coupe I would recommend two of them. I was really surprised how different the two banks on my car are when I added a second sensor. With 8 carbs you can dial that in pretty good if you have the info. The two banks might not have different AFR, you might have an exhaust leak on the side that reads lean. Or you might have one wideband that is reading off. You can swap the sensors side to side to see if the problem follows the sensor or stays with the side. If it stays with the side then I'd bet you have a small exhaust leak. We see this all the time on the dyno and I've never found the issue to be with the engine. It is always with the sensors or the exhuast system. Most engines just don't run richer or leaner on one side than the other unless the induction system is really strange.
[Re: Twostick]
#2371940
09/16/17 11:24 PM
09/16/17 11:24 PM
CSK
Pattison Texas
I could see different bank to bank AFR on a long ram as it basically turns the engine into two four cylinder engines. Getting 2 carbs to make identical fuel curves on what is effectively 2 similar but separate engines would be quite a challenge.
I don't think the balance tube would make any difference to speak of on this as far as AFR is concerned at least above idle.
Kevin Yep you would be correct, but a single plane intake only needs 1 o2 sensor.
[Re: CSK]
#2371993
09/17/17 12:24 AM
09/17/17 12:24 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin Yep you would be correct, but a single plane intake only needs 1 o2 sensor. Apparently I thought I was quoting BBM's post. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Oops.. What kind of induction is Bad340fish running? Kevin
[Re: Hemi_Joel]
#2372016
09/17/17 01:05 AM
09/17/17 01:05 AM
Hemi_Joel
Minnesota
This would be for my coupe. The 2 plenums on the cross ram intake are not connected, so 2 meters would be a good idea.
[Re: Twostick]
#2372017
09/17/17 01:06 AM
09/17/17 01:06 AM
CSK
Pattison Texas
Kevin Yep you would be correct, but a single plane intake only needs 1 o2 sensor. Apparently I thought I was quoting BBM's post. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Oops.. What kind of induction is Bad340fish running? Kevin Sorry Kevin, confusion on my part lol ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) no harm no foul
[Re: CSK]
#2372043
09/17/17 02:05 AM
09/17/17 02:05 AM
Twostick
Still wishing...
Still wishing...
Kevin Yep you would be correct, but a single plane intake only needs 1 o2 sensor. Apparently I thought I was quoting BBM's post. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Oops.. What kind of induction is Bad340fish running? Kevin Sorry Kevin, confusion on my part lol ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) no harm no foul Lol. No problem, I thought I was quoting BBM who was talking about a long ram setup when it was actually Bad340fish. He said he was seeing a difference bank to bank so now I'm curious what his setup is. Kevin
[Re: Twostick]
#2372102
09/17/17 09:52 AM
09/17/17 09:52 AM
Bad340fish
Tulsa OK
Kevin Yep you would be correct, but a single plane intake only needs 1 o2 sensor. Apparently I thought I was quoting BBM's post. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Oops.. What kind of induction is Bad340fish running? Kevin Single plane indy intake for W2 heads. Its got lots of camshaft so it has a lot of reversion which makes a mess of the intake at low flow scenarios. Its port fuel injected so the fuel part is consistent but the airflow will cause variances. I knew that happened and have seen several cases of it but I didn't realize it would be so much. The amount of fuel feeding the two banks can be very different at low rpm and low load. Like I said before once you get tipped into the throttle and the RPM comes up it all falls into line. Joel, they make a nice digital gauge that runs two sensors but that may not be the look you want with your coupe.
[Re: Hemi_Joel]
#2372824
09/18/17 04:50 PM
09/18/17 04:50 PM
Hemi_Joel
Minnesota
I went ahead and ordered a pair of MTX-L. Thanks for all the help!
