Which studs with main girdle? #2370788
09/14/17 03:53 PM
09/14/17 03:53 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I got a girdle for cheap but it came without any studs. Which studs do I need to buy to run it? I already have main studs but they are too short. Also which studs for the oil pan?
Engine is a 440.
thanks
Re: Which studs with main girdle? [Re: DGS] #2370803
09/14/17 04:41 PM
09/14/17 04:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Looking at my old ARP box I used 240-5501 with a 3/8" girdle
Re: Which studs with main girdle? [Re: DGS] #2370809
09/14/17 04:54 PM
09/14/17 04:54 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Thanks! Do you know how long they are? I'd rather buy single studs than a complete kit as I have several nuts and washers lying around.
Re: Which studs with main girdle? [Re: DGS] #2370826
09/14/17 05:41 PM
09/14/17 05:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You could put a screw driver in the main hole and measure up to the top of the girdle and add 1" for the nut,washer plus 2 threads.The rear,front dtud are just 1/4" shorter for pan clearence.I will see if I can get to the engine that has those studs in it.
Re: Which studs with main girdle? [Re: DGS] #2370841
09/14/17 05:53 PM
09/14/17 05:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I got 1 out and it is 5.250" long with 1 1/4" thread goes into the block and 2" fine thread at the top of the main cap for 2 nuts,washers,girdle.[some shims may be needed]
ps:The measurement I gave is for another kit I have no part # but the 1 I gave is for a windage tray also so it has a longer stud that has a stem for the tray.
Re: Which studs with main girdle? [Re: DGS] #2370843
09/14/17 05:55 PM
09/14/17 05:55 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Awesome! Thanks a lot!
Re: Which studs with main girdle? [Re: DGS] #2370851
09/14/17 06:03 PM
09/14/17 06:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
no problem
