Re: Axle tube stamping
[Re: 70 buzz]
#2370924
09/14/17 08:54 PM
09/14/17 08:54 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No "stamping" that I know of but some had a wrap-around sticker with the last digits of the part number.
[Re: 70 buzz]
#2370950
09/14/17 10:06 PM
09/14/17 10:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Where was the broadcast number applied on the axle tube? I was thinking it was passenger side near the leaf springs looking from the back of the car you would be able to see the numbers ...this about all you'll see on a Dana
[Re: 70 buzz]
#2371596
09/16/17 03:25 AM
09/16/17 03:25 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Where was the broadcast number applied on the axle tube? I was thinking it was passenger side near the leaf springs looking from the back of the car you would be able to see the numbers The broadcast number applied by paint stamp to axles was not intended to be viewed after the car was assembled. It's use was to identify axles on racks at the assembly line for workers to pick the correct one for assembly according to the broadcast sheet for each car. My 8.75" axle was paint stamped "565" upside down and inboard a couple of inches of the driver side spring perch. It was located on the forward side. So after assembly you would need to crawl under the car in front of the left rear wheel to view it upside down.
[Re: kentj340]
#2371611
09/16/17 07:28 AM
09/16/17 07:28 AM
Posts: 1,893 michigan
70 buzz
michigan
Where was the broadcast number applied on the axle tube? I was thinking it was passenger side near the leaf springs looking from the back of the car you would be able to see the numbers The broadcast number applied by paint stamp to axles was not intended to be viewed after the car was assembled. It's use was to identify axles on racks at the assembly line for workers to pick the correct one for assembly according to the broadcast sheet for each car. My 8.75" axle was paint stamped "565" upside down and inboard a couple of inches of the driver side spring perch. It was located on the forward side. So after assembly you would need to crawl under the car in front of the left rear wheel to view it upside down. Lynch road car?
