Re: 11.75 rotors
[Re: 340dart4spd ]
#236964
02/26/09 09:43 PM
02/26/09 09:43 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
Scarebird is now selling a bushing for the inner wheel bearing so you can use later discs on early spindles. The later bearing has a larger ID than the earlier one. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: 11.75 rotors
[Re: DoctorDiff]
#236969
02/28/09 01:08 AM
02/28/09 01:08 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Mopar Action 11.75 disk swap This is one of Mopar Action's all time best tech articles. Correct geometry, all chrysler parts, and the whole shooting match will run you under 4 bills. When I pulled together the parts for my cuda, I used NAPA for rotors, hoses, bearings calipers (They let me exchange a couple B body cores for the E's ). My local Dodge dealer rounded up dust shields and I landed a set of semi metalic cop break pads for me (I think they are all gone now). I also went with the mopar aluminum master cylinder and MP/Willwood proportioning valve. My spindles came from a 73 feather duster and my brackets came from a StRegis (Junk yard items). You will enjoy the article. Rick Ehernberg is the man.
I’m listening.
Re: 11.75 rotors
[Re: DoctorDiff]
#236971
02/28/09 01:30 PM
02/28/09 01:30 PM
Posts: 8,501 Candler,NC / Myrtle Beach, SC
JDMopar
Yes, my bushing and seal package allows a '73 and newer rotor to work with '70-'72 B/E body disc knuckles.
You must also run '73 and newer caliper brackets.
Doc....do the adapter bushings have to be pressed onto the spindles? It would seem like they would need to be so they wouldn't rotate
Re: 11.75 rotors
[Re: Lee446]
#236974
02/28/09 03:01 PM
02/28/09 03:01 PM
RapidRobert
I'd like to nab a set myself. I think the last pair I saw here was $75 which is too high for me. I didn't have the money at the time(still dont ).
Re: 11.75 rotors
[Re: DoctorDiff]
#236977
03/01/09 01:36 AM
03/01/09 01:36 AM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
The only 11.75" caliper brackets available are used.
that's a part that should be reproduced. I had a tough time finding them 10 years ago when I did the swap
Re: 11.75 rotors
[Re: Pool Fixer]
#236978
03/01/09 08:04 AM
03/01/09 08:04 AM
Posts: 3,819 Arlington, Texas
bobby66
Arlington, Texas
Master Power advetised those for a while, but I haven't seen them lately.
