So that distributor sent me to bed tonight feeling totally defeated, I feel like I got my ass kicked by that thing.
I gave up, I tried a hole behind the original hole on the reluctor I bought at the parts store and it wasn't happy with it because of some of the teeth being longer then some of the others I think the reluctor teeth were smacking on the pick up coil post.
Not 100 percent sure, I just heard it making a strange noise around the distributor that changed tone with the timing.
So I grabbed the original reluctor that came on the firecore distributor, picked a different tooth that hadn't had any drilling done on it yet, went about 15 degrees ccw from the tooth.
Put it back on dropped the distributor back in the truck and started it and it's running rough as hell hardly wanting to idle, i shut it off and slammed the hood and said [censored] you im done.
So first thing tomorrow morning Rick ehnerberg is getting 35 dollars of my hard earned money for one of his reluctors and I'll have my fingers crossed that it works.
The closest I can this weekend to having the rotor properly phased was when I shared the photo of it being a little too far forward from the cap terminal, after that it all went to [censored] and I started having problems drilling straight holes into the reluctors and having problems getting the roll pins to go in the slots that I drilled, hearing strange noises from the distributor with the part store reluctor and then having the truck not even wanting to idle after a long a new hole.
It was just a total ass bearing with that truck winning by knock out in the first couple rounds.
