Re: My Magnafuel 275 has died
[Re: justinp61]
#2367772
09/09/17 04:53 AM
09/09/17 04:53 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Been running a Aeromotive pump daily and racing the last 4 years (?) maybe . Quiet and no dramas . The one below a 1000 series . Oh i also fitted their return regulator at the same time . Went from a Holley hp150
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: rebel]
#2367853
09/09/17 11:50 AM
09/09/17 11:50 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
i've had a lot of luck with the Magnafuel. both my racecar & my streetcar run the 275. both have never had an issue. whats actually wrong with the pump? I don't have it off yet but it appears the motor is locked up.
[Re: justinp61]
#2367869
09/09/17 12:38 PM
09/09/17 12:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It sounds like it was fat also being that you went quicker when the pump was dying.. so after you get a pump try leaning it down EDIT I was running a pair of 140s on my stuff before I swapped to injection but 1 of them would work for you(Mallory 140)
[Re: justinp61]
#2367870
09/09/17 12:39 PM
09/09/17 12:39 PM
Posts: 25,950 United Socialist States of Ame...
tboomer
Justin...Maybe you will get lucky. A few weeks back that Holley HP 150 locked up on me. Took it apart and cleaned up the gear assembly and it works just fine! I did install an Aeromotive S/S 11203 pump that works great! It may be a bit noisy for the street. Good luck!
[Re: justinp61]
#2367881
09/09/17 01:03 PM
09/09/17 01:03 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In the past, Magnafuel has been excellent to deal with for parts and service. I'd call them before buying a new pump.
[Re: fast68plymouth]
#2367921
09/09/17 03:04 PM
09/09/17 03:04 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
[Re: justinp61]
#2368294
09/10/17 01:39 PM
09/10/17 01:39 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Get another pump... Work on the tune-up and the power management for whatever track your running.... Spinning ant winning..... I agree... Sounds too fat..
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: stevet340]
#2368469
09/10/17 08:59 PM
09/10/17 08:59 PM
justinp61
W. Kentucky
More than likely the small bearing nearest the fuel inlet and outlet froze up. I've seen 2 magnafuel pumps do this in the past 3 days... The bearing shouldn't cost more than $5-$10. DING DING DING.........We have a winner! Guys if your Magnafuel pump starts leaking replace the bottom bearing when you do new seals. It could save you some grief.
[Re: justinp61]
#2368718
09/11/17 10:54 AM
09/11/17 10:54 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
If you still decide to get another one, the Aeromotive 11203 is a real good little pump. I ran one for a long time on my car running mid 9s at 3800 lbs...just a simple deadhead system w/ -8 line.
[Re: justinp61]
#2368785
09/11/17 01:02 PM
09/11/17 01:02 PM
Triple Threat
Renton Washington
More than likely the small bearing nearest the fuel inlet and outlet froze up. I've seen 2 magnafuel pumps do this in the past 3 days... The bearing shouldn't cost more than $5-$10. DING DING DING.........We have a winner! Guys if your Magnafuel pump starts leaking replace the bottom bearing when you do new seals. It could save you some grief. My magnafuel 300 did the exact same thing. I sent mine back to MF and they fixed it up for me.
