426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? #2363705
09/01/17 08:14 PM
09/01/17 08:14 PM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
This multi-pic should be a good starting point.,,
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: xs29j8] #2365110
09/04/17 12:37 PM
09/04/17 12:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks for doing this. It's nice to see someone take the time to share what they know with others. up
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: 6PakBee] #2365796
09/05/17 02:25 PM
09/05/17 02:25 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Who is making one for a Mopar Mega block that has a NPT thread in place of a drilled hole? It seems all other dipsticks are too large for this threaded hole?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: xs29j8] #2365834
09/05/17 03:20 PM
09/05/17 03:20 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Thanks, Alan!
Matt
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: 6PKRTSE] #2366284
09/06/17 10:50 AM
09/06/17 10:50 AM
moparx Offline
moparx  Offline
for this application, you would need to use a female "tube" fitting that matches the size of your dip stick with a male NPT that matches your block threads on the opposite end. to use the factory style dipstick, you would have to remove the "bubble" that seats the stick in the block, cut the stick tube to the desired length, attach the tube to the fitting in the block, then fill the pan with the correct amount of oil and mark the stick accordingly.
beer
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: mattsmopars] #2366536
09/06/17 06:28 PM
09/06/17 06:28 PM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
Great to see some discussion starting on the variety of Hemi oil dipsticks used,
& see attached of some of the related components used on the installation.
Here in a side-by-side comparison of the heat shield, about the only thing close to accurate is the overall color of generally white..
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: xs29j8] #2366617
09/06/17 08:50 PM
09/06/17 08:50 PM
Fort Worth, Texas
xs29j8 Offline OP
xs29j8  Offline OP
Fort Worth, Texas
The mounting clip is dimensionally different, even though it has the same general appearance .... note the angular difference on the bend lines.
Aw
Re: 426 Hemi Oil Dipsticks - Prod Line, NOS, Repro Comparison? [Re: xs29j8] #2366625
09/06/17 09:01 PM
09/06/17 09:01 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I had a hard time installing a repo, broke it off at the swage that is supposed to stop it from going into the block further. So 1 each compression fitting and tap the block, good as new and no one will ever crawl under my car to look at it.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
