Re: superperformance valve cover gaskets
[Re: mopar dave]
#2366296
09/06/17 11:27 AM
09/06/17 11:27 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
If the surface is not flat,,,,,,leak you will.Don't ask how I know
[Re: roadhazard]
#2366324
09/06/17 12:10 PM
09/06/17 12:10 PM
BradH
Those are new to me. I've used the "thick" Fel-Pro gaskets mentioned above, but like fast68plymouth mentioned, they delaminate (peel apart?) during the first disassembly. If my standard Superformance VC gaskets have any sealing issues w/ Indy cast covers on Edelbrock Victor heads (something odd about the Victor's valve cover rail, as I recall from AndyF), then would the Carbon-X be your next suggestion?
[Re: BradH]
#2366881
09/07/17 11:51 AM
09/07/17 11:51 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Those are new to me. I've used the "thick" Fel-Pro gaskets mentioned above, but like fast68plymouth mentioned, they delaminate (peel apart?) during the first disassembly. If my standard Superformance VC gaskets have any sealing issues w/ Indy cast covers on Edelbrock Victor heads (something odd about the Victor's valve cover rail, as I recall from AndyF), then would the Carbon-X be your next suggestion? If you have the Superformance #3186 Micropore-15 valve cover gaskets check and be sure the valve cover sealing surface is flat. You won't have any issues.
[Re: mopar dave]
#2366893
09/07/17 12:07 PM
09/07/17 12:07 PM
roadhazard
Akron, Ohio U.S.A.
yep, mine leak real bad if i put any RPM on engine, 4000 up. mine look like they leak at the top. driving with the hood off pushes the oil to the front of the valley tray making it look like the chain cover is leaking. ????? So if your valve covers are leaking at the "top" which is very unusual. Would there not be oil pooled on the cylinder head and intake manifold? Looking at your picture there is plenty of area for oil to pool on your (Victor?) heads. Hood off or not, oil up by the timing cover might suggest your valley cover or possibly even your distributor is leaking. I don't know, I'm not there. "You" need to confirm exactly where the leak is coming from. May not be the valve covers at all.
[Re: DaveRS23]
#2366899
09/07/17 12:21 PM
09/07/17 12:21 PM
roadhazard
Akron, Ohio U.S.A.
I like and use Superformance gaskets.....in certain places. They are the ONLY thing that I have found that can stop my intake from sucking oil. But their valve cover gaskets leaked on my Hemi. Just my . I will refer you to my previous comment.... "When someone purchases from Superformance Products they get real, honest and cohesive tech support direct from the manufacturer. Take advantage of that benefit." The root cause of your problem could have been addressed with a simple phone call, sorry you didn't take advantage of that. Thanks for your support
[Re: dartman366]
#2366903
09/07/17 12:28 PM
09/07/17 12:28 PM
roadhazard
Akron, Ohio U.S.A.
Carbon-X is what I used on mine with the Indy no logo covers and dry as a bone. Bill, I would have suggested the #3186 Micropore-15 gaskets for your application, that's what they were made for. The Carbon-X will work though. As always, thanks for your support
[Re: roadhazard]
#2366931
09/07/17 01:23 PM
09/07/17 01:23 PM
BradH
Those are new to me. I've used the "thick" Fel-Pro gaskets mentioned above, but like fast68plymouth mentioned, they delaminate (peel apart?) during the first disassembly. If my standard Superformance VC gaskets have any sealing issues w/ Indy cast covers on Edelbrock Victor heads (something odd about the Victor's valve cover rail, as I recall from AndyF), then would the Carbon-X be your next suggestion? If you have the Superformance #3186 Micropore-15 valve cover gaskets check and be sure the valve cover sealing surface is flat. You won't have any issues. The issue isn't whether the cast valve cover flange and the cylinder head valve cover rail are both flat (they are), but an overhanging issue like I believe AndyF brought up previously. When I put the MP-15 gasket on the valve cover, it's a pretty good match. When I put the same gasket on the head, it overhangs the intake-side of the valve cover rail noticeably, leaving only part of the gasket to seal on the head while the outer edge is covered up by the exposed lip of the underside of the valve cover flange. This is an Edelbrock BB Victor design eff-up, but it is what it is.
[Re: mopar dave]
#2366961
09/07/17 02:24 PM
09/07/17 02:24 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I've probably said this a million times but "not everything works with everything". It isn't like there is an official Mopar aftermarket certification board that hands out stamps of approvals for Mopar parts. People just make stuff and sell it and maybe it fits and maybe it doesn't. Exactly.
[Re: BradH]
#2367003
09/07/17 03:35 PM
09/07/17 03:35 PM
roadhazard
Akron, Ohio U.S.A.
Those are new to me. I've used the "thick" Fel-Pro gaskets mentioned above, but like fast68plymouth mentioned, they delaminate (peel apart?) during the first disassembly. If my standard Superformance VC gaskets have any sealing issues w/ Indy cast covers on Edelbrock Victor heads (something odd about the Victor's valve cover rail, as I recall from AndyF), then would the Carbon-X be your next suggestion? If you have the Superformance #3186 Micropore-15 valve cover gaskets check and be sure the valve cover sealing surface is flat. You won't have any issues. The issue isn't whether the cast valve cover flange and the cylinder head valve cover rail are both flat (they are), but an overhanging issue like I believe AndyF brought up previously. When I put the MP-15 gasket on the valve cover, it's a pretty good match. When I put the same gasket on the head, it overhangs the intake-side of the valve cover rail noticeably, leaving only part of the gasket to seal on the head while the outer edge is covered up by the exposed lip of the underside of the valve cover flange. This is an Edelbrock BB Victor design eff-up, but it is what it is. So what you are telling me is the gasket does not cover the whole flange on the cylinder head and there is exposed sealing area area? I understand what is being said about the alignment of the valve cover flange in reference to the cylinder head flange not being in optimum alignment. If you had .125" or more of contact area where the valve cover and the cylinder head meet on the top sealing surface it should be enough to load the gasket and create a seal. Now let's just say you only had .125" of good contact area between the valve cover and cylinder head along the top rail. If you "increase" the thickness of the gasket it will tend to roll/twist the gasket on that flange and give you the shear that Andy speaks of. More thickness and softer density will make the matter worse. Can you set the gasket on the head, throw in some bolts for alignment and snap a pic or two of the flange area?
[Re: mopar dave]
#2367031
09/07/17 04:23 PM
09/07/17 04:23 PM
fast68plymouth
So. Burlington, Vt.
Another reason the MP cast covers can be difficult to seal with thinner, less compliant gaskets is there are irregularities cast into the sealing surface area.
Even if the covers aren't warped, the gasket surface isn't "flat"(smooth).
Brad, if you have a sharpie/marker, you could color up the upper v/c rail on the head, lay the gasket on it, and scribe a line of where the inner edge of the gasket sits. After pulling the gasket off, you'd be able to see how much overlap there is.
[Re: roadhazard]
#2367068
09/07/17 05:30 PM
09/07/17 05:30 PM
BradH
So what you are telling me is the gasket does not cover the whole flange on the cylinder head and there is exposed sealing area area? Yep. Can you set the gasket on the head, throw in some bolts for alignment and snap a pic or two of the flange area? Yep.
[Re: BradH]
#2367202
09/07/17 10:05 PM
09/07/17 10:05 PM
roadhazard
Akron, Ohio U.S.A.
So what you are telling me is the gasket does not cover the whole flange on the cylinder head and there is exposed sealing area area? Yep. Can you set the gasket on the head, throw in some bolts for alignment and snap a pic or two of the flange area? Yep. Thank you! look forward to the pics
[Re: mopar dave]
#2367204
09/07/17 10:13 PM
09/07/17 10:13 PM
roadhazard
Akron, Ohio U.S.A.
ok, I found the extensive part of the oil leak. Was leaking from the valley pan directly under the intake. Pulled the cover, cleaned it up good and sealed it with the Right Stuff. Installed the cork valve cover gaskets, went for a power ride and no leaks. non, not even a drop. Cool, I'm sure happy with that cause this thing was leaving pools of oil on the cover. You would be amazed at the amount of oil that slings off the cam and hits the bottom of the valley plate/ bathtub gasket! Maybe the valve cover gaskets were not leaking after all but as we discussed over the phone, would be good to get them surfaced flat over the winter, put the original gaskets back on and roll with it. Nice chatting with you Dave
[Re: fast68plymouth]
#2367475
09/08/17 02:39 PM
09/08/17 02:39 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Brad, if you have a sharpie/marker, you could color up the upper v/c rail on the head, lay the gasket on it, and scribe a line of where the inner edge of the gasket sits. After pulling the gasket off, you'd be able to see how much overlap there is. Again, I'm using MP covers that do not leak a drop after about 8 years and yes, the thin red ones. Silicon-ed to the covers on rpm heads..........
