prepping for paint - which way to go? #2365570
09/05/17 12:44 AM
09/05/17 12:44 AM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Got multiple resto projects starting. First is my son's 72 cuda. after metal work going to go get it blasted. Well by me is newbury sand blasting. A few of my friends have used them, some like them. They blast firewall, underneath and panels. I met a guy at the piston power show. ECO blast, water based with glass. They are out of valley city. Anyone ever use this process? doing the cuda, then my lil red then my vert. wanted to hear some thoughts. Need to find a lot of restoration services, chrome interior, etc. got name of shops for work to be done please drop me an email. thx phil par12730@sbcglobal.net
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: prepping for paint - which way to go? [Re: hulmule] #2365723
09/05/17 12:11 PM
09/05/17 12:11 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
I think I'd have the blasting done before metal work. It will most likely uncover more problems which may require the completed metal work to be redone.
The water based blasting is an excellent way to go, although not exactly cheap. If you choose the sand blaster, I would not let him use sand since it can easily warp the metal. I would have them use some sort of media like walnut shells.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: prepping for paint - which way to go? [Re: hulmule] #2365818
09/05/17 03:03 PM
09/05/17 03:03 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
The mobile blaster company( that blasted my car) was shut down by the government for creating " too much dust"....
Probably the future with the water added to keep down dust...
Re: prepping for paint - which way to go? [Re: hulmule] #2365924
09/05/17 05:45 PM
09/05/17 05:45 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The water helps the glass do a better job at removing everything including undercoating. Stil have the same huge mess afterwards.
Re: prepping for paint - which way to go? [Re: hulmule] #2365947
09/05/17 06:43 PM
09/05/17 06:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Dipping is the only way to go. It gets it all. Even after blasting - where the blaster can actually get - there will be minute rusty pores that are too small for blast media. This rust must be removed or converted. So you may as well do it right the first time - dip the car and get ALL the rust.
Re: prepping for paint - which way to go? [Re: Stanton] #2365957
09/05/17 07:02 PM
09/05/17 07:02 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Well I've heard nightmares about dipping. If it didn't get cleaned well ,the acid ate through the paint. It's my son's car, limited budget. Dip then e coat- pretty pricey. Don't even know where one would be. They closed one out by Toledo I'm told. Was thinking more on the ECO water blast cause water helps cool and no warp age. keep the restoration tips coming. Just got home from summit with a right side quarter, trunk pan and gutters. Need more info on correct restoration. where to get services in my area. Chrome, interior etc. May try interior - installing seat covers myself.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: prepping for paint - which way to go? [Re: hulmule] #2366034
09/05/17 09:09 PM
09/05/17 09:09 PM
Minn
SportF Offline
SportF  Offline
Minn
I've used the water/glass bead method twice now and I think its great. And I don't think its any more expensive than other methods. AND, he came to my place to do it, so there was no loading, unloading repeat.
The real draw back is the stuff cakes in the nooks and crannies and is hard to get it out. But, I will do it again.
Re: prepping for paint - which way to go? [Re: hulmule] #2366097
09/05/17 10:53 PM
09/05/17 10:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Old wives' tales perpetrated by proponents of blasting. Haven't you ever heard of blasters warping panels ?!?!
Re: prepping for paint - which way to go? [Re: Stanton] #2366116
09/05/17 11:17 PM
09/05/17 11:17 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
that occurs when you are brain dead stupid
and you blast the outside panels..
dipping = 2500 and up plus transportation costs
i could probably blast/strip 4-5 cars for the same money
Re: prepping for paint - which way to go? [Re: flypaper] #2366172
09/06/17 12:38 AM
09/06/17 12:38 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
If I had done things differently I would of had the body dipped. Exposes all sins in the body. Unlike sand and soda the dipping is neutralized and coated to eliminate flash rust.
Soda and sand can come back to haunt a painter.
Abe Lincoln
Re: prepping for paint - which way to go? [Re: hulmule] #2366196
09/06/17 01:32 AM
09/06/17 01:32 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
But you can't convince some people of that !
And if someone says they can blast a car for $500 you should probably avoid them like the plague!
Re: prepping for paint - which way to go? [Re: Stanton] #2366200
09/06/17 01:39 AM
09/06/17 01:39 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
why is that??
i do it all myself
that is about what the media and stripper will cost me give or take a few.
blast the inside and underside
and chemically strip all the outside panels
the way you talk,
you are either made of money or own a dipping company..lol
its not a matter of convincing,
its a matter of economics! realcrazy
for a 100k plus hemi car..sure
for your average mopar ... realcrazy
Re: prepping for paint - which way to go? [Re: hulmule] #2366234
09/06/17 05:53 AM
09/06/17 05:53 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Dipping is the only way to go on any car that may have hidden rust. The blaster can't get inside frame rails or any area you can't see. Dip the car and everything is cleaned. Blast it and do it over in 5 yrs when it rusts. Never enough money to do it right but enough money to do it over.
Real Men shift for themselves
Re: prepping for paint - which way to go? [Re: hulmule] #2366329
09/06/17 12:17 PM
09/06/17 12:17 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The op asked which style of blasting... I've only ever sandblasted and the only negative to me is the time it takes to get all the sand out of the rail, seams, rockers etc. It's not as bad when the car is on a rotiserrie, but still takes a lot of time. I'm working on a car now that when I removed the floors there was an inch of sand in areas from being blasted before and not cleaned correctly.
As far as dipping since it's being discussed... wouldn't do it if it was free. The less chemicals used the better.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: prepping for paint - which way to go? [Re: hulmule] #2366342
09/06/17 12:33 PM
09/06/17 12:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
why is that??
i do it all myself
the way you talk,
So you're saying you can do this for a customer for $500., because that’s what we’re talking about here, the OP having it done – not doing it himself. If a guy told me he could blast a customer’s car for $500. I would be extremely concerned about what I get back.
As for the "chemical" and "acid" comments, its really evident that you guys are just listening to the old wive's tales and have done ZERO research on the topic.
And no, I don't own a stripping company !!
Re: prepping for paint - which way to go? [Re: Stanton] #2366352
09/06/17 12:53 PM
09/06/17 12:53 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have dipped several cars and there are issues with dipping. I had a hood that would not take paint afterwards, that company was in business for 40 years. It all depends on how often they change the solvent in the dipping tanks and how much the employees care about their work. work A buddy used the same dipper and they forgot about his doors they had in the tank and put a body on top of them! eek When they finally realized their mistake he got two smashed and nearly gone doors because they were in the solution too long. tsk The last dipper in area is a Redi Strip facility and they are very expensive and booked solid for months out... shruggy I had a floor stripped by a company that used Black Beauty, too bad they didn't mask off the new headliner, what a mess! Had to replace the headliner and am still removing left over residue from the blasting months later. mad
JB Rhinehart, Realist
A-Body's RULE!
Re: prepping for paint - which way to go? [Re: hulmule] #2366426
09/06/17 02:43 PM
09/06/17 02:43 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
There are a number of ways to do this. Much of it depends on how deep your pockets are and how much work you want to put in. For the low buck route...Several gallons of aircraft paint stripper, a box of razor blades and a razor blade scraping knife works for large flat panels. The same paint stripper, a wire brush and Scotch Brite pads work on the irregular surfaces. Might need to add a heat gun or propane torch for the under coating removal.
For the smaller hard to reach areas, corners, etc, get a cheap suction feed blaster from Harbor Freight. Inside the frame areas, tape off the drain holes and pour a bit of Evapo-Rust inside to help take care of that. The rust transformer stuff also works well for those inside hidden areas.
Bad rust as always should be cut out and replaced. However don't fall into the trap of replacing entire panels because of one small bad area. Weld the patch in place and save what you can of the original metal.
1972 Dodge Challenger
Re: prepping for paint - which way to go? [Re: hulmule] #2368046
09/09/17 09:49 PM
09/09/17 09:49 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
"Much of it depends on how deep your pockets are" . This is a 22 year old young mans car. My son is in his senior year of college. He's carrying 18 credits, has 3 jobs working for the college for money. Not that I want him to do it wrong or nor does he, but money isn't falling out of his pockets. glad he's into muscle cars and not other stuff. We still have to install trunk pan and passenger quarter then paint..Then figure out money for motor, find a 4 speed. (original 3 speed 340 car) , interior etc. will probably go with water/glass blasting. but I like info ,I have a 2 lil reds to do and my R/T convertible.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: prepping for paint - which way to go? [Re: hulmule] #2368275
09/10/17 01:18 PM
09/10/17 01:18 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i blast for a living. i own a wet blaster, a dry blaster and a vapor blaster,. i blast soda, walnut, aluminum oxide, garnet, glass bead and 5 sizes of glass.
my opinion is based on real work, not something i read on the internet from "a guy who knows a guy who... posts his opinion on moparts" i work on big money cars everyday and have my preference is dry blasting.
first off. have the blaster show you their work (i have 2600 photos on my phone of work i have done for others) have them give you references on work they have done in the past. if they specialize in heavy equipment and "might be able" to do your car, run away. you want a sheetmetal blaster.
wet blasting is NO different than dry blasting other than its wet and messy. you can still warp. if you fall for the cooling metal BS, its just hype. most dustless blasters (green blast pot) have little experience blasting and no training from mmlj so be careful and do your homework on whats involved after blasting.
the only wet blasting i do other than concrete and rock is sail boats. no sheetmetal at all. I would never fill a car with wet product. too hard to remove and you have a short time to remove it even with holdtight in the water.
media size. ask them about it as well. i blast 100-200 grit glass on sheetmetal. it leaves little to no profile (1-2mil) floors, inners ect i use 50-100 grit glass. anything coarser in my opinion is too rough.
everybody has their own opinion on blasting/stripping and thats good. i know what works for me and have lots of happy customers to show for it.
Re: prepping for paint - which way to go? [Re: hulmule] #2368289
09/10/17 01:33 PM
09/10/17 01:33 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
this is a picture from a fellow blaster who took the picture. i know the full story behind it and the picture was not found on the internet. this camaro is a fresh 10.5 car that just had the cage done and the customer wanted the car blasted. new blaster wet blasted it and this is the results. the doors were full of wet media and all the panels are ruined. i think this one will be a lawsuit.
i am not biased to one type of blasting, so this isnt hacking wet blasting, mmlj is the green guys advertising on the tv car shows. they used to be called sodablast systems and made a horrible media hog product. they added water to the system and started dustless blasting. same crappy machines, just hype.
