Hood hinge 69 A body
#2365325
09/04/17 06:03 PM
09/04/17 06:03 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
How do you get the hood hinge off a 69 A body?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: Hood hinge 69 A body
[Re: 6T9Hemi]
#2365334
09/04/17 06:32 PM
09/04/17 06:32 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
pull, really really hard there are clips on the pivot pin and spring end under the fender top then it pretty much falls right off. accessable if you take the splash shield out but much easier with the fender off.
[Re: Jim_Lusk]
#2366276
09/06/17 10:12 AM
09/06/17 10:12 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
I tried the hardware store push clips. They were not nearly strong enough. Popped them off the first time I tried to close the hood. Spend the money for good clips. In a pinch I tried fuel line size hose clamps - the good ones, not offshore junk. Been on there for years.
