1&7/8'or2"pri hdrs for ang. plug 500"strker?ATTN ZIPPY!
#23610
03/13/06 07:44 PM
03/13/06 07:44 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Read the moparts tech section, Hookers are definitely OUT, Both Thorley and hedman Elite have 1&3/4"primaries, engine builder (Dvorak)recommended 2', I could probably live with 1&7/8 if i could find them, don't really wanna pay 5-800for TTIs to use on my "Rat rod" SE chall...BTW this is for my "mild" 500" bulldog headed solid cam RB 4 spd DOT tires 3500lb car.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker?
[Re: RTSE4ME]
#23612
03/13/06 08:11 PM
03/13/06 08:11 PM
Sixgun
Western Washington
OK, RTSE...but rea d our tech section here on Moparts if you are going with any angle plug head...I found the return rates at Summit particularly interesting. THX, C
[Re: Sixgun]
#23613
03/13/06 08:47 PM
03/13/06 08:47 PM
Sixgun
Western Washington
Come on, gang...I KNOW a lot of you got Eddys, Indys, and Bulldogs...whatre y'all using?
[Re: Quicksilver440]
#23615
03/14/06 04:06 PM
03/14/06 04:06 PM
Sixgun
Western Washington
yeah, youre probably right...aggravation IS costly.
#23617
03/15/06 08:36 AM
03/15/06 08:36 AM
Posts: 660 East Lansing, Michigan
OldHippie
super gas
super gas
From what I have seen there is only one tube that has to be "loveingly massaged" on a set of Hooker 2" Super Comps with the angle plug heads. Contact Zippy, he has a set of 1 7/8" Hooker Comps on his Eddy headed Charger and i think he only had to mildly clearance one or two tubes for plug socket clearance. I have a set of 1 7/8" Super Comps for my Eddy headed 451 low deck and #2 tube is a nightmare, bashed the devil out of it to get plug boot clearance. #8 needed slight clearancing for the plug socket to go on. Everything else is good to go.
The Old Hippie Hisself
[Re: ZIPPY]
#23622
03/15/06 11:20 PM
03/15/06 11:20 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Will be switching to 2" Super Comps shortly,
[Re: whiplash]
#23623
03/15/06 11:42 PM
03/15/06 11:42 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
The comp 1 7/8" work great on strokers if you replace the 3" collector with a 3 1/2", it's the collector that's the bottleneck mor than the primary diameter.
[Re: whiplash]
#23627
03/20/06 03:09 PM
03/20/06 03:09 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
Test fit is done, send me money John
