5.7 MDS block off plugs #2361470
08/28/17 11:56 PM
08/28/17 11:56 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline OP
JT612GTX  Offline OP
Newby here on gen 111 Hemi anyways,heres my dilema.
Bought a rebuilt 5.7 long block from a local engine builder for my 2004
Dodge Ram 1500,got it all installed, primed the engine and discovered oil running out of the MDS holes which were not supposed to be there. trucks not wired for them, question is can I just install the block off plugs or do I have to change out the non MDS tappet set as well.
Thanks in advance for any input, teaching an old dog new tricks here
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2361478
08/29/17 12:07 AM
08/29/17 12:07 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You must to have solenoids in place if you have MDS lifters.
If you remove the MDS lifters, then you can remove the solenoids and install block plugs.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2361521
08/29/17 01:49 AM
08/29/17 01:49 AM
JT612GTX Offline OP
JT612GTX  Offline OP
So this may be a dumb question, what if I install solenoids just to plug
holes and not functional since the trucks not wired for them, would that work? weighing out my options here.
Thanks GGC for your response, I really appreciate it!
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2361555
08/29/17 05:04 AM
08/29/17 05:04 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Yes that will work. I would ask the engine builder which lifters the engine has in it. I would bet it does have MDS lifters in it. If it does have the MDS lifters in it I would put four solenoids in the holes and be done with it. It's the fastest way to get it running. If it happens to have non-MDS lifters in the engine then it's as simple and MDS plugs...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2361573
08/29/17 09:15 AM
08/29/17 09:15 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes, dead solenoids will work to fill the hole and keep the MDS lifters from actuating.
2020 RAM 1500
Re: 5.7 MDS block off plugs [Re: GoodysGotaCuda] #2361841
08/29/17 06:32 PM
08/29/17 06:32 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
I too am new to gen 3 hemis my problem may be coming from somethimg in these posts had to replace an engine in our 04 Durango non mds reman engine shows up and doesn't have mds plugs or solonoids so order up 4 plugs and put them in as I was told that is only difference between non mds ormds engines 5 months later hasn't made it out of my garage yet when you first start it it seems to idle decent but after about 30 seconds or so sounds like it has a couple weak cylinders and no power revs slow and sounds like a 4 or 6 cylinder shut it off let it set a couple minsutes start it and the same scenario replaced practically every sensor fuel pump plugs twice one coil pack acts like lifters pump up and let it drop cylinders would this act that way from putting just the mds plugs in instead of the dead solonoids
Re: 5.7 MDS block off plugs [Re: webemopes] #2361842
08/29/17 06:34 PM
08/29/17 06:34 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
forgot to mention I have no idea which lifters are in this engine and would install a set of the mds solonoids instead of pulling the heads and changing out the lifters
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2361988
08/29/17 10:16 PM
08/29/17 10:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
you need to put in 4 solenoids not plugs and it will fire up and run great.
Re: 5.7 MDS block off plugs [Re: webemopes] #2362089
08/30/17 12:25 AM
08/30/17 12:25 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The spark plugs will be brand new on 1, 4, 6, and 7. I know a little bit about running block plugs with MDS lifters...[don't]
Obviously, I know better now and the unplugged solenoids are the way to go.
2020 RAM 1500
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2363909
09/02/17 04:42 AM
09/02/17 04:42 AM
Australia
L4staero Offline
L4staero  Offline
Australia
So just to revisit this do both the int and exh lifters on that cyl bleed down?
Can i take 8 sets of mds lifters in yokes and make a full set of 4 non mds lifters by swapping out the msd ones for non mds
Re: 5.7 MDS block off plugs [Re: L4staero] #2363922
09/02/17 08:25 AM
09/02/17 08:25 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Yes.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 5.7 MDS block off plugs [Re: L4staero] #2363923
09/02/17 08:29 AM
09/02/17 08:29 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Can i take 8 sets of mds(did you mean NON MDS) lifters in yokes and make a full set of 4 non mds lifters by swapping out the msd ones for non mds
you can swap NON MDS lifters for MDS liters.
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2364299
09/02/17 11:33 PM
09/02/17 11:33 PM
Australia
L4staero Offline
L4staero  Offline
Australia
And how do u identify mds vs non mds lifters when they are out of the yoke
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2364408
09/03/17 03:39 AM
09/03/17 03:39 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
MDS lifters have the bleed hole in the side. Non-MDS lifters do not. That's the main visual difference I believe. I know they take different yokes as well. It's possible the machining at the top of the lifters, where they engage the yokes, is different. Someone with more knowledge will chime in and clear up the confusion hopefully...
SuperBeast
Re: 5.7 MDS block off plugs [Re: L4staero] #2364424
09/03/17 09:17 AM
09/03/17 09:17 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
As mentioned, MDS have a hole in the side.
2020 RAM 1500
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2364620
09/03/17 03:04 PM
09/03/17 03:04 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
MDS on the left, the top of the MDS are thicker were it slips in the yoke, yokes are different.
Re: 5.7 MDS block off plugs [Re: ric3xrt] #2365649
09/05/17 08:51 AM
09/05/17 08:51 AM
Australia
L4staero Offline
L4staero  Offline
Australia
I started pulling down my motor today.
Further to that as above I noted non mds clips have the plunger held in with a hex shaped wire clip.
The MDS lifter plunger is held in with a circlip
NON MDS wire clip
MDS Circlip
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2536984
08/16/18 12:49 AM
08/16/18 12:49 AM
Janesville, WI
O
Onlooker Offline
Onlooker  Offline
O
Janesville, WI
So of I have a 6.4 with mds I can just leave the mds unplugged and the engine should run properly?
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2537192
08/16/18 02:47 PM
08/16/18 02:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
yes
Re: 5.7 MDS block off plugs [Re: JT612GTX] #2541487
08/26/18 10:07 AM
08/26/18 10:07 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I'm glad I found this. I have a 06 ram but have a 04 motor in it now. We took the plugs out of the 06 motor and put into the 04 then plugged up the MDS system up hoping it will think its still a MDS motor but the trucks shakes really bad at 50ish until I put it in trailer mode. What can I do to stop this bad shake?
Re: 5.7 MDS block off plugs [Re: GoodysGotaCuda] #2541488
08/26/18 10:12 AM
08/26/18 10:12 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
So unplugging the solenoids would be better than having them plugged in? with a 04 motor in my 06 truck
