1&7/8'or2"pri hdrs for ang. plug 500"strker?ATTN ZIPPY! #23610
03/13/06 07:44 PM
03/13/06 07:44 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Read the moparts tech section, Hookers are definitely OUT, Both Thorley and hedman Elite have 1&3/4"primaries, engine builder (Dvorak)recommended 2', I could probably live with 1&7/8 if i could find them, don't really wanna pay 5-800for TTIs to use on my "Rat rod" SE chall...BTW this is for my "mild" 500" bulldog headed solid cam RB 4 spd DOT tires 3500lb car.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Sixgun] #23611
03/13/06 08:04 PM
03/13/06 08:04 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I am building a 505 stroker and every engine builder I talked with recommends 2" primary with 3.5" collecter. I think the hooker 5209s are the least expensive. I will be running 1 3/4" headers for now because I have firm feel long steering arms but everyone has told me that i will lose around 50hp.
I think it would be worth the money for 2" headers.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: RTSE4ME] #23612
03/13/06 08:11 PM
03/13/06 08:11 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
OK, RTSE...but rea d our tech section here on Moparts if you are going with any angle plug head...I found the return rates at Summit particularly interesting.
THX, C
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Sixgun] #23613
03/13/06 08:47 PM
03/13/06 08:47 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Come on, gang...I KNOW a lot of you got Eddys, Indys, and Bulldogs...whatre y'all using?
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Sixgun] #23614
03/13/06 09:20 PM
03/13/06 09:20 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I have 2" TTI's on my 446 with eddy heads....fit great. I'd use a 2" on a 500" motor.
The 2" Hookers CAN be made to work too....Unlawful had them on his challenger with eddy heads and no problems.
I tried the 1 7/8" Hooker supercomps and eddys and they burned boots constantly....I changed them out for the TTI's.
Thats all I know really....
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Quicksilver440] #23615
03/14/06 04:06 PM
03/14/06 04:06 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
yeah, youre probably right...aggravation IS costly.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Sixgun] #23616
03/15/06 04:06 AM
03/15/06 04:06 AM
Central Valley, CA.
Central Valley, CA.
I do think you could get away with the 2" supercomps...
I've heard the 1-7/8" "COMPS" (not supercomps) can be made to work...but I don't know that for sure. Those are only $170...
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Quicksilver440] #23617
03/15/06 08:36 AM
03/15/06 08:36 AM
East Lansing, Michigan
O
OldHippie Offline
super gas
OldHippie  Offline
super gas
O
From what I have seen there is only one tube that has to be "loveingly massaged" on a set of Hooker 2" Super Comps with the angle plug heads. Contact Zippy, he has a set of 1 7/8" Hooker Comps on his Eddy headed Charger and i think he only had to mildly clearance one or two tubes for plug socket clearance. I have a set of 1 7/8" Super Comps for my Eddy headed 451 low deck and #2 tube is a nightmare, bashed the devil out of it to get plug boot clearance. #8 needed slight clearancing for the plug socket to go on. Everything else is good to go.
The Old Hippie Hisself
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: OldHippie] #23618
03/15/06 06:27 PM
03/15/06 06:27 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Yep. I have a set of 1 7/8 SuperComps on an Eddy headed 500 stroker and the inside curve of the number 2 tube has to be dented (hammered) in about 25% of it's diameter just to get the plug started into the head let alone put a boot on it. Just about every other plug is a PITA to install or remove and I used the Accel shorty's which are about 1/8" shorter. I have heard that the 2" SC's are better due to different tube positioning.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Sixgun] #23619
03/15/06 07:46 PM
03/15/06 07:46 PM
snook Offline
snook  Offline
I use Hooker 2-1/8" with 4" collectors race adjustables, perfect for my 400 based 452 stroker. I use eddy heads, fit perfect.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: OldHippie] #23620
03/15/06 07:55 PM
03/15/06 07:55 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
OH is correct, with E heads and 1 and 7/8 Comps (not Super Comps)I had to very slightly ding 2 tubes on the passenger's side. No big deal, I've had the same plug wires since 2001 or so and have never burned a boot.
Will be switching to 2" Super Comps shortly, Looks like some mild dinging of #1 is all that will be needed.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: ZIPPY] #23621
03/15/06 09:10 PM
03/15/06 09:10 PM
Central NC
gch Offline
gch  Offline
Central NC
i have e-heads on my 465 in a 73 charger.tti 2"fit well but anything less than WOT car was slower.it is heavy and not a lot of converter or gear(at the time).i have regular comp 1 7/8 hookers on there now.i had to clearance for the steering box and coupler(different clearance issues on 73-74).for more street than strip 1 7/8 would be fine.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: ZIPPY] #23622
03/15/06 11:20 PM
03/15/06 11:20 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: whiplash] #23623
03/15/06 11:42 PM
03/15/06 11:42 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
The comp 1 7/8" work great on strokers if you replace the 3" collector with a 3 1/2", it's the collector that's the bottleneck mor than the primary diameter.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Streetwize] #23624
03/20/06 02:57 AM
03/20/06 02:57 AM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Yeah, but what about my Track dawg bulldogs, i reaal don't know if they actually are configured same as eddys...I suppose they SHOULD be...
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Sixgun] #23625
03/20/06 09:59 AM
03/20/06 09:59 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
I use TTI 2 1/8 Gotta let them 500's get rid of exhaust
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sro [Re: cyphre666] #23626
03/20/06 01:51 PM
03/20/06 01:51 PM
beepilot Offline
beepilot  Offline
I use 2" Hooker Supercomps on my 440/496 Edelbrock heads in my 71 Charger Superbee. I only had to ding a couple places for frame clearance and inner fender on the passenger side. I do have to use a motorcycle/snowmobile type sparkplug socket on #1 plug. You know, one of those thin sheetmetal stamped cheapies that come in a motorcycle tool kit....works great.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: whiplash] #23627
03/20/06 03:09 PM
03/20/06 03:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Test fit is done, send me money John
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: ZIPPY] #23628
03/20/06 03:17 PM
03/20/06 03:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I ran the 5903's Hooker comps with some small dempling on the #8 tube due to angle plug clearance, the Bulldogs may fit betterm I was thinking they used stock eshaust location, where eddys are moved 3/8's or so. Also the header collector was tight near the driver side orsion bar, this was in a 69 B body with RB engine. spark plug changing sucked but you get faster after doing it a few times.
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker? [Re: Bob_Coomer] #23629
03/22/06 11:27 AM
03/22/06 11:27 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Results are in, 5309 2" SC's work with fewer modifications than 5903 comps. The previous owner had already put one small ding in #1 pipe, and that's all it took. Right bank is easy as pie, no mods needed. So...either one works fine with minor tweakage, but the 2" ones need less work.
