1&7/8'or2"pri hdrs for ang. plug 500"strker?ATTN ZIPPY!
#23610
03/13/06 07:44 PM
03/13/06 07:44 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Read the moparts tech section, Hookers are definitely OUT, Both Thorley and hedman Elite have 1&3/4"primaries, engine builder (Dvorak)recommended 2', I could probably live with 1&7/8 if i could find them, don't really wanna pay 5-800for TTIs to use on my "Rat rod" SE chall...BTW this is for my "mild" 500" bulldog headed solid cam RB 4 spd DOT tires 3500lb car.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: 1&7/8' or 2" pri headers for angle plug RB 500" sroker?
[Re: RTSE4ME]
#23612
03/13/06 08:11 PM
03/13/06 08:11 PM
Sixgun
Western Washington
OK, RTSE...but rea d our tech section here on Moparts if you are going with any angle plug head...I found the return rates at Summit particularly interesting. THX, C
[Re: Sixgun]
#23613
03/13/06 08:47 PM
03/13/06 08:47 PM
Sixgun
Western Washington
Come on, gang...I KNOW a lot of you got Eddys, Indys, and Bulldogs...whatre y'all using?
[Re: Quicksilver440]
#23615
03/14/06 04:06 PM
03/14/06 04:06 PM
Sixgun
Western Washington
yeah, youre probably right...aggravation IS costly.
#23617
03/15/06 08:36 AM
03/15/06 08:36 AM
Posts: 660 East Lansing, Michigan
OldHippie
super gas
super gas
From what I have seen there is only one tube that has to be "loveingly massaged" on a set of Hooker 2" Super Comps with the angle plug heads. Contact Zippy, he has a set of 1 7/8" Hooker Comps on his Eddy headed Charger and i think he only had to mildly clearance one or two tubes for plug socket clearance. I have a set of 1 7/8" Super Comps for my Eddy headed 451 low deck and #2 tube is a nightmare, bashed the devil out of it to get plug boot clearance. #8 needed slight clearancing for the plug socket to go on. Everything else is good to go.
The Old Hippie Hisself
[Re: ZIPPY]
#23622
03/15/06 11:20 PM
03/15/06 11:20 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Will be switching to 2" Super Comps shortly,
[Re: whiplash]
#23623
03/15/06 11:42 PM
03/15/06 11:42 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
The comp 1 7/8" work great on strokers if you replace the 3" collector with a 3 1/2", it's the collector that's the bottleneck mor than the primary diameter.
[Re: whiplash]
#23627
03/20/06 03:09 PM
03/20/06 03:09 PM
Posts: 17,843 S.E. Michigan
ZIPPY
S.E. Michigan
Test fit is done, send me money John
[Re: ZIPPY]
#23630
03/28/06 02:57 AM
03/28/06 02:57 AM
Sixgun
Western Washington
So Zippy...#5309 2" SuperComps? Are these a "slip together" header , and will I have a "normal" collector to bolt up exhaust to? All things considered is this the best choice in your opinion for my app? Are the 1&7/8" Comps your second choice? Thanks, Casey
[Re: Sixgun]
#23632
03/29/06 12:10 PM
03/29/06 12:10 PM
Sixgun
Western Washington
Spoke to my "personal" Summit guy last night, he swears no such# as 5309 in Hooker catalog, says it must be 5209 = 2" super comp @419.00 The 1 7/8" are 199.00.Leaning towards these for my Rat Rod challenger, even tho I'm sure the 2" would be better.John RR said he got some good #s from the 1 7/8".Rvoyles, where can I get that 170.00 price on the 1&7/8" comps? Thanks for all the good info, guys!Saves me time and $! Casey
[Re: Sixgun]
#23634
03/31/06 03:33 AM
03/31/06 03:33 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
That was the price when I was looking...but that was a few years back...they must have went up. Still pretty cheap though...
[Re: Sixgun]
#23635
03/31/06 11:43 AM
03/31/06 11:43 AM
ZIPPY
S.E. Michigan
Casey, Yep he is right, the pn really is 5209 for the 2". Brain fart They have one slip tube that wraps around the torsion bar, and they do have a 3.5" collector ring for a bolt-on exhaust. The 1&7/8 also work fine, but most of them need 2 small dings so the plug socket will go on. A few folks have had good luck not dinging and instead using an open end wrench for spark plugs, or grinding the socket to shorten it, but I never tried that. Besides budget, the only question that is left is which one to use? IMO the 1&7/8 are fine for a street car. Mine ran low 11's with 1&7/8 through the exhaust, and picked up nothing with open headers. If it weren't for the never ending quest for a 10 second run, I wouldn't bother with the 2".
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#23636
03/31/06 11:56 AM
03/31/06 11:56 AM
Sixgun
Western Washington
THANKS ZIPPY!!!!!!!!!!!!!!!!!! Aloha, Casey
