Re: Very Happy with ET'S
[Re: cudabunch]
#236082
02/25/09 06:03 PM
02/25/09 06:03 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
Sweet. You and I are right there. . I have a 446 also. 10.8:1 SRP flat tops, steel crank,Victor 440 on a set of ported and milled E-heads, Holley 850dp, 4000 PTC, 4.10's in a Sure Grip driving 275/60 ET Streets.. Read under my sig pic.. Trying for 10.?? this summer..
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: forphorty]
#236088
02/26/09 01:31 AM
02/26/09 01:31 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 63 or my sons Dart would be a good race for you. They are both street cars also. My 63 has a .030 over 440 with stock bottom end and KB pistons that give me 10.0 comp with my 906 heads and I use the MP .557 cam. My suspension is stock and I was using air shocks also with a stock monroe shock up front and I use a Dynamic 9.5 converter. 11.52 @ 116 is my best with a best 60 of 1.58 and I use 4.30's with a 29" rear tire.. Your car is running very good and it has more in it with the 118 mph. We run a .030 over 400 in my sons car with Eddy heads and 3.91's and he also uses the MP .557 cam. His car has hit an 11.45 @ 117 so far. Work on your 60 now as you have at least 11.20's with your mph. Good luck. Ron
