Page 12 of 12 1 2 10 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Jerry] #2342905
07/25/17 03:48 AM
07/25/17 03:48 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Originally Posted By Jerry
i'm here, you can pm me here. I've got kids at camp and i'm in and out of the office. we have the cps bushings on the shelf as well as our crank trigger kits for big blocks and small blocks. IF they would have asked rich wouldn't have had to reinvent the wheel
Your PM box is full. I cant pm you. I'd like to get one of those Bushings.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2342934
07/25/17 09:04 AM
07/25/17 09:04 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
all cleaned out. parts are in stock and ready to ship
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2360887
08/27/17 11:32 PM
08/27/17 11:32 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Any Idea what voltage the Jeep cam sensor uses? 5 or 12vts? Same question for the GM crank trigger sensor. Any ideas?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2360896
08/27/17 11:47 PM
08/27/17 11:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
i have my jeep sensor running on 5v
68 Barracuda Formula S 340
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Bad340fish] #2360990
08/28/17 02:54 AM
08/28/17 02:54 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
How about the crank trigger? I am using the sdconcepts trigger kit. Its a gm style sensor.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2361079
08/28/17 11:54 AM
08/28/17 11:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can't speak for the GM sensor but I am running 5V to my crank sensor. It is a Cherry Brand hall effect sensor that will run on 5-24V. Great sensors for anything that spins.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2445774
02/03/18 06:44 PM
02/03/18 06:44 PM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
Any updates or tweaks to this? I can't find any deals on Camaro/Firebird harnesses anywhere.Prices on any used stuff have exploded since this was written.
Re: My 440 EFI-Coil on Plug/LS PCM ignition-UPDATED PINOUTS [Re: Quicksilver440] #2446350
02/04/18 05:34 PM
02/04/18 05:34 PM
AndyF Offline
AndyF  Offline
Here is the setup I have for my low deck 470. I still need to get some custom wires from Gorski and then I'll be ready to fire it up. (once it is back in the car of course)
Re: My 440 EFI-Coil on Plug/LS PCM ignition-UPDATED PINOUTS [Re: Quicksilver440] #2447188
02/06/18 12:22 AM
02/06/18 12:22 AM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
Sweet Andy...can't wait to see it in the car.Can you tell me more about the intake you used?
Re: My 440 EFI-Coil on Plug/LS PCM ignition-UPDATED PINOUTS [Re: Quicksilver440] #2447225
02/06/18 01:07 AM
02/06/18 01:07 AM
AndyF Offline
AndyF  Offline
It is a Trick Flow intake that has been ported by Wilson Manifolds. They also did the EFI conversion for me.
