Re: Garage Project
[Re: skicker]
#2356270
08/18/17 10:29 PM
08/18/17 10:29 PM
Posts: 1,030 ohio
67mprfan
ohio
Hey Q what's the blue car in the background
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Garage Project
[Re: 67mprfan]
#2357476
08/21/17 10:45 AM
08/21/17 10:45 AM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
These two?? 65 Bel II 4 door and a 64 Polara 2dr H/t...Both for parts...Two more things I should have already been finished with...Just not enough hours in the day... ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif)
...FAFO...
Re: Garage Project
[Re: skicker]
#2357480
08/21/17 10:58 AM
08/21/17 10:58 AM
skicker
"The Champ"
"The Champ"
Western Md.
The rest of the roof metal was installed Saturday... I know it doesn't look like much but I got all of the wood framing finished for the 36" soffit at the front. I moved over to the east elevation and installed the home wrap and the window and door. I picked up all of the siding...soffit and J trims this morning. I need to p/u 6 4" round light boxes to install for the exterior sconces at the front wall and at all of the doors. Tonight the transmission comes out of the 69 Dart to fix a broken flex plate and install a slightly bigger convertor. I won't be back into this until Wednesday.
...FAFO...
Re: Garage Project
[Re: skicker]
#2357570
08/21/17 02:07 PM
08/21/17 02:07 PM
skicker
"The Champ"
"The Champ"
Western Md.
The windows, door frame and the door sill were set in a bed of silicone sealant. The inside gaps were then caulked back to the wood framing. The bottoms of the windows were not caulked on the outside so as to not trap water if it were to penetrate the window frames. Window's were purchased with the J channel for the siding already incorporated into the frames. Door frames were ordered for 2x6 walls with extended jambs and the PVC trim and frame assembly that is designed to not rot out.
...FAFO...
Re: Garage Project
[Re: skicker]
#2357576
08/21/17 02:20 PM
08/21/17 02:20 PM
skicker
"The Champ"
"The Champ"
Western Md.
A couple pics of the soffit framing and a stack of siding and soffit that will be the next phase to begin. ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) All siding and soffit are Mastic Products. Color for the siding is "Harbor Grey". Grey J channel will be used on the ends with eaves under the soffit and around the door frames while white soffit trim will be used at the front and rear elevations at the rear of the soffit. I'm going to make all of the exterior fascia and soffit trim using the .040 aluminum typical to the inside at the garage doors rather than the thin rolled products readily available. I have some pretty neat materials ordered for the front elevation...no maintenance at all... I'll post pics once they come in... Garage door supplier was on site and measured the openings after the trim installation so once they arrive they will be installed also. ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
...FAFO...
Re: Garage Project
[Re: skicker]
#2359939
08/25/17 10:51 PM
08/25/17 10:51 PM
skicker
"The Champ"
"The Champ"
Western Md.
The garage door install is scheduled for Monday and Tuesday... ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I spent all last night installing all of the light boxes and the siding blocks for the electrical devices. Set the laser up and shot all 4 elevations with a control line to measure from. I was able to start installing the siding tonight on the east elevation. I'll continue with the back tomorrow and then fall back and finish the eave above. It's hard to beat using the windows with the J trim for the siding incorporated around them. Turns out to be a really clean finish...
...FAFO...
Re: Garage Project
[Re: skicker]
#2360151
08/26/17 02:15 PM
08/26/17 02:15 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
I spent all last night installing all of the light boxes and the siding blocks for the electrical devices. It's hard to beat using the windows with the J trim for the siding incorporated around them. Turns out to be a really clean finish...
The options for vinyl sideing are pretty cool nowadays.. They were not around when I did my first house and it was alot more work....
Re: Garage Project
[Re: floridian]
#2361350
08/28/17 09:03 PM
08/28/17 09:03 PM
skicker
"The Champ"
"The Champ"
Western Md.
Saturday was a good day as I managed to set the back door and get all of the siding and soffit on the rear elevation.
...FAFO...
Re: Garage Project
[Re: skicker]
#2361351
08/28/17 09:08 PM
08/28/17 09:08 PM
skicker
"The Champ"
"The Champ"
Western Md.
Sunday was a short day. We built the scaffold on the east elevation and installed the balance of the exterior sheathing on the truss's. I cleaned up for a while and moved material around for the garage door installation on Monday.
...FAFO...
Re: Garage Project
[Re: skicker]
#2361355
08/28/17 09:14 PM
08/28/17 09:14 PM
skicker
"The Champ"
"The Champ"
Western Md.
They managed to get the 10' garage door installed today. The 16' door is scheduled for tomorrow... The tracks allowed the door to be 4" below the trusses at the back side. The Liftmaster 8500 garage door opener was also installed today.
...FAFO...
Re: Garage Project
[Re: skicker]
#2361816
08/29/17 05:44 PM
08/29/17 05:44 PM
skicker
"The Champ"
"The Champ"
Western Md.
They managed to get the 16' garage door installed today... Just started raining here so i doubt I get to do anything tonight... ![frowwn frowwn](/ubbthreads/images/graemlins/custom/frowwn.gif)
...FAFO...
Re: Garage Project
[Re: skicker]
#2365224
09/04/17 03:13 PM
09/04/17 03:13 PM
Superfreak
Superfreak
The windows, door frame and the door sill were set in a bed of silicone sealant. The inside gaps were then caulked back to the wood framing. The bottoms of the windows were not caulked on the outside so as to not trap water if it were to penetrate the window frames. Window's were purchased with the J channel for the siding already incorporated into the frames. Door frames were ordered for 2x6 walls with extended jambs and the PVC trim and frame assembly that is designed to not rot out. This type of window install would not be allowed here.
Re: Garage Project
[Re: ]
#2367642
09/08/17 10:08 PM
09/08/17 10:08 PM
skicker
"The Champ"
"The Champ"
Western Md.
I managed to get most of the aluminum trim bent up for the eaves so if the rain stays away tomorrow I'll work on that. I have a friend who is also building a new garage and borrowed a LED light fixture from him to try in mine. It's a high bay light with 20,000 Lumens. Somewhat pricey but not as bad as some I have seen. It is so bright that its almost a distraction...I feel like I'm working in something using the old halogen light stands that light everything up fine but if you look at them they're blinding... Granted these pics aren't the greatest but it really seems to cast a lot of shadows creating dark areas.. See what you think...I may need to come up with a better plan... ![work work](/ubbthreads/images/graemlins/custom/work.gif)
...FAFO...
Re: Garage Project
[Re: skicker]
#2367652
09/08/17 10:33 PM
09/08/17 10:33 PM
skicker
"The Champ"
"The Champ"
Western Md.
This is the fixture turned off with a couple 4' led tube lights I had for temporary lights on instead. One pic from outside with the door open and then closed. Its definitely bright but being a high bay fixture designed for taller ceilings it feels like a big spotlight. I think I need to look at less Lumens and more fixtures to eliminate the shadowing... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
...FAFO...
Re: Garage Project
[Re: skicker]
#2367765
09/09/17 02:48 AM
09/09/17 02:48 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Re: Garage Project
[Re: RSNOMO]
#2368515
09/10/17 10:07 PM
09/10/17 10:07 PM
skicker
"The Champ"
"The Champ"
Western Md.
They're tall enough for my junk... Fortunately they're not tall enough for that...darn... ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I installed the rest of the soffit...flashing and siding on the East elevation. I used the .040 Aluminum rather than the thin stuff... It is a bright white and really pops against the grey siding and the roofing. Finally I get a look at it without the scaffolding... Now to repeat it on the other side... ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif)
...FAFO...
