440 RB Water Pump #2359719
08/25/17 04:10 PM
08/25/17 04:10 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
I need to replace the stock water pump on my Challenger 440BB (street driver). I am not overheating with my present pump and thermostat, but I am running close to the edge. I'd like to replace with a higher flow/volume pump and thermostat setup. I just want to replace the impeller and keep the cast iron housing. Any suggestions??
Re: 440 RB Water Pump [Re: 70VERT] #2359720
08/25/17 04:14 PM
08/25/17 04:14 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
doesn't the pump for a/c big-blocks have more impeller vanes than the non-a/c version? Would be easier to get a parts-store pump than to change out the impeller twocents
Re: 440 RB Water Pump [Re: 70VERT] #2359729
08/25/17 04:27 PM
08/25/17 04:27 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Not looking to change just the impeller. I want to replace the bolt on impeller assembly that bolts to the pump housing. Mine is a non-AC car.
Re: 440 RB Water Pump [Re: 70VERT] #2359738
08/25/17 04:41 PM
08/25/17 04:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What you are calling the bolt on impeller assembly is the water pump.
What you want to keep is the water pump housing.
Don't be the exception.
Re: 440 RB Water Pump [Re: 70VERT] #2359744
08/25/17 04:57 PM
08/25/17 04:57 PM
dogdays Offline
dogdays  Offline
That is the water pump. When you go to the parts store and say 440 water pump that's what they'll bring you.
The water pump housing is between the water pump and the block.
Edelbrock pumps are supposed to increase flow
FlowKooleer pumps likewise
Milodon sells some pretty good stuff and their water pump should be good
Don't try to install a cavitation plate on a pump. If you want this feature, buy the FlowKooler.
This subject is funny because back in the day a water pump was a water pump. Whatever Genuine Parts had on the shelf was IT. Or H. E. Everson.
R.
Re: 440 RB Water Pump [Re: dogdays] #2359789
08/25/17 06:20 PM
08/25/17 06:20 PM
BlueRacer69 Offline
BlueRacer69  Offline
R.
Milodon big block high flow water pumps already come with a cavitation plate already attached. Mine did anyway. The only thing I was disappointed in was it only had 6 vains. And if you don't already have a high flow thermostat, get one of those too.
Re: 440 RB Water Pump [Re: 70VERT] #2359800
08/25/17 06:46 PM
08/25/17 06:46 PM
How hot? is that a known accurate gauge? Is the issue stoplight to stoplight or on the highway or both? any recent part changes preceding a temp change? what setup do you have now (fan/schroud/radiator etc) timing/AF ratio in the ballpark? If the pump is needed a parts house 8 blader will suffice & you can cut a circular disc in half & tack weld the halves behind the vanes for an efficient anticav plate.
Re: 440 RB Water Pump [Re: DrCharles] #2359817
08/25/17 07:02 PM
08/25/17 07:02 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Less; A/C has 6 vanes, non-A/C has 8 vanes. A/C pump is overdriven 40%.
Many parts stores offer only the 6-vane pump for all applications. Can cause overheating.
Re: 440 RB Water Pump [Re: John_Kunkel] #2359914
08/25/17 10:13 PM
08/25/17 10:13 PM
IN
ahy Offline
ahy  Offline
IN
If I were replacing a water pump and T stat today, I would pick the Mancini Racing high volume pump and Milodon stat.
That said, "close to overheating" is often/usually not a stat or pump issue. Usually the radiator is getting marginal, there is an issue with the fan & clutch or shroud is missing or damaged.
Hot rolling down the road usually means radiator is marginal. Hot at a standstill (only) usually means fan/clutch/shroud is hurting.
Re: 440 RB Water Pump [Re: John_Kunkel] #2360076
08/26/17 11:14 AM
08/26/17 11:14 AM
moparx Online content
moparx  Online Content
and aren't the ac pulleys smaller in diameter with the crank pulley at still 7 1/4" ? or do i have this backward ?
beer
Re: 440 RB Water Pump [Re: moparx] #2360108
08/26/17 12:45 PM
08/26/17 12:45 PM
Yes overdriven 33%. With the AC, a condensor/larger (thicker) radiator used/needed, so with AC a faster fan speed was needed to move enough air at idle/lower speeds thru these obstructions but this faster pulley also cavitated the pump at higher RPM's so going to only 6 vanes took care of that at high RPM's & the faster pulley speed made the 6 vanes move enough coolant at idle/low RPM's. The axle ratio will affect this. My suggestion(s). 8 blade/adj vane clearances/cav plate/good high flow 180 or higher stat/MP clutch or rigid fan with the most blades/spaced properly into a schroud/air directed correctly thru rad/several drops of dawn dish soap/a 1/32 hole in the stat for fast fillup/elim air pockets on initial startup. A good setup will feel like a tornado in front of the radiator.
Re: 440 RB Water Pump [Re: 70VERT] #2360363
08/26/17 11:07 PM
08/26/17 11:07 PM
BlueRacer69 Offline
BlueRacer69  Offline
Not to high jack this thread, but I have a pulley question here. So if I'm running a 6 vane water pump which is supposably for an A.C. car, what size should the crank pulley be? (single groove crank pulley, 440 car). Thanks.
Re: 440 RB Water Pump [Re: BlueRacer69] #2360414
08/27/17 12:57 AM
08/27/17 12:57 AM
7 & 1/4"
Re: 440 RB Water Pump [Re: RapidRobert] #2360424
08/27/17 01:43 AM
08/27/17 01:43 AM
BlueRacer69 Offline
BlueRacer69  Offline
Originally Posted By RapidRobert
7 & 1/4"
I thought the crank pulley was suppose to be smaller in diameter for an A.C. car? I just measured mine and its 6 1/2 inchs across. (single groove pulley).
Re: 440 RB Water Pump [Re: BlueRacer69] #2360537
08/27/17 12:22 PM
08/27/17 12:22 PM
You may be right on that. I had just assumed that the pump one was reduced to overdrive it. Can you measure your pump pulley?
Re: 440 RB Water Pump [Re: 70VERT] #2360539
08/27/17 12:24 PM
08/27/17 12:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.bouchillonperformance.com/products-pulleys
First off, single groove pulleys are for non AC setups, so you are already off in your combo.
The above link will have the diameters.
Re: 440 RB Water Pump [Re: BlueRacer69] #2360578
08/27/17 01:56 PM
08/27/17 01:56 PM
BlueRacer69 Offline
BlueRacer69  Offline
7 & 1/4"
The water pump pulley is approximately 6 & 13/16. And as I said before the crank pulley is 6 & 1/2 inch.
Re: 440 RB Water Pump [Re: Supercuda] #2360583
08/27/17 02:02 PM
08/27/17 02:02 PM
BlueRacer69 Offline
BlueRacer69  Offline
This is a non AC car, but it has a 6 vane water pump on it, which if I understand it right is for a AC car. So if I'm running a 6 vane water pump what size should the crank pulley & water pump pulley be?
Re: 440 RB Water Pump [Re: BlueRacer69] #2360584
08/27/17 02:05 PM
08/27/17 02:05 PM
^^^ As you know you are underdriven (with deep(er) gears likely good as is above idle). A 8 blader (easier than a pulley swap)) would give more flow.
Re: 440 RB Water Pump [Re: 70VERT] #2360600
08/27/17 02:36 PM
08/27/17 02:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just run the non AC pump, cheaper swap.
GATES 42032 $21.00 at Rock Auto
As to what pulleys to run, the Bouchillion site has that info.
Re: 440 RB Water Pump [Re: 70VERT] #2360610
08/27/17 03:06 PM
08/27/17 03:06 PM
BlueRacer69 Offline
BlueRacer69  Offline
My thanks to RapidRobert & Supercuda for the info.
Re: 440 RB Water Pump [Re: BlueRacer69] #2361231
08/28/17 05:24 PM
08/28/17 05:24 PM
dogdays Offline
dogdays  Offline
To: the whole freakin' world:
THE NUMBER OF VANES ON AN IMPELLER IS NOT THE DECIDING FACTOR AS TO HOW MUCH IT FLOWS.
You cannot make that generalization.
I bet there are maybe 15 board members who understand centrifugal pumps. I selected and tested them for 19 years. If you know what the affinity laws are, you are one of the 15.
Now to the burning question: WHY is it so important to get the last bit of coolant flow? Answer...
More's Law
If some is good
Then more is better, and
Too much is just right.
When you are driving down the highway your engine is producing less than 100hp. At 60 it is 35hp. At 80 it's roughly 65hp. That means that a radiator from a Dart would cool it okay.
Chrysler was a company in which engineering was king. So when they installed different impellers and pulley ratios I have to think it was for a real reason. It would probably been less expensive to adopt a "one size fits all" mentality. These cars were not known for overheating back in the day. They were pulling Airstreams. They were going 70 or faster. They drove for hours on end. My friend's Dad would tell him, "Just one more state before we stop to use the bathroom."
I had one car that didn't have a large enough cooling system, a Datsun B-210. Put the speedometer on 75 and after about 10 minutes the temp gauge would start creeping up. Drop back to 65 and it'd go right back to the middle of the gauge.
When I hear talk about big pumps I always think to myself "horsepower wasters".
End of lecture.
R.
