'70 Challenger Rear Valance Area -what goes here? Pics
#2354881
08/16/17 02:46 PM
08/16/17 02:46 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I noticed a mounting hole near my rear spring hanger/ bumperette mounting area. I have no idea what is supposed to be mounted in it. Any ideas? I'm talking about the hole pretty much dead center in the first picture. There is one on the other side too.
Re: '70 Challenger Rear Valance Area -what goes here? Pics
[Re: Kevin Kowalski]
#2354904
08/16/17 03:48 PM
08/16/17 03:48 PM
challenger70
Berwyn, IL
It looks like the location where the welded bracket part of the rear valance bolts to. There's one on either side of the rear license plate area. Did you try to match up a valance? This is right by the leaf spring and the bolt that holds whatever would go vertical into this hole. It does not hold anything with the valence I have, mine has the 2 brackets that have 2 horizontal holes on the rear facing part of this piece of sheet metal.
[Re: challenger70]
#2354960
08/16/17 05:17 PM
08/16/17 05:17 PM
Posts: 43,248 Bend,OR USA
Cab_Burge
Tailpipe or muffler hangar hole?
[Re: challenger70]
#2355034
08/16/17 07:40 PM
08/16/17 07:40 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
My '72 Cuda had a muffler heat shield that ran front to back on both sides (dual exhaust) in that area. I think that there was a bolt that went into that clip and held the rear portion of the shield up.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#2355340
08/17/17 10:33 AM
08/17/17 10:33 AM
challenger70
Berwyn, IL
My '72 Cuda had a muffler heat shield that ran front to back on both sides (dual exhaust) in that area. I think that there was a bolt that went into that clip and held the rear portion of the shield up. On '70 Challengers it's tucked up by the trunk floor and the frame rail. The rear of the shield is held on by the exhaust hanger. Some type of mount for the California exhaust, seems to be the best possibility so far...but it seems too close to the leafspring.
[Re: challenger70]
#2355362
08/17/17 11:01 AM
08/17/17 11:01 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Tailpipe or muffler hangar hole? it's pretty far back for that, but my car is a California car, I think they required turndowns which may have mounted farther back... than the standard dual exhaust. Only California Hemi and Sixpack cars require turndowns with dual exhaust
[Re: burdar]
#2355603
08/17/17 06:28 PM
08/17/17 06:28 PM
challenger70
Berwyn, IL
1970 used different brackets to attach the rear valance. Do you have the correct style valance on the car or are you using the 71-74 style with the large center mounting bracket?
I have the correct (I believe) for a '70 Challenger brackets. they use 2 holes on the back of this part that go horizontal into it. This hole is on the bottom of that panel and the screw goes vertical, just inside of where the bumperette mounts. That big bolt you see is the bolt for the bumper bracket if that helps with referencing where it is.
[Re: challenger70]
#2355623
08/17/17 07:37 PM
08/17/17 07:37 PM
Posts: 318 Iowa
ratroaster
Iowa
These threaded holes were used for 2 more L shaped brackets that only came on a few cars. They quit using them sometime in the production year. Not seen on most survivor cars unless they are early build dates. However, I have a 70' 318 car built in Hamtramck with a SPD of 209 that has them. No rhyme or reason why. It's a mystery as to why a few got them or not. See the thread below for more info. LINKY
[Re: ratroaster]
#2358512
08/23/17 11:54 AM
08/23/17 11:54 AM
challenger70
Berwyn, IL
These threaded holes were used for 2 more L shaped brackets that only came on a few cars. They quit using them sometime in the production year. Not seen on most survivor cars unless they are early build dates. However, I have a 70' 318 car built in Hamtramck with a SPD of 209 that has them. No rhyme or reason why. It's a mystery as to why a few got them or not. See the thread below for more info. LINKY Mystery solved, thanks! Mine is a pretty early October '69 built car so this makes sense. Now to try yo track some of those brackets down...
[Re: challenger70]
#2358532
08/23/17 12:29 PM
08/23/17 12:29 PM
Challenger 1
Cincinnati, Ohio
These threaded holes were used for 2 more L shaped brackets that only came on a few cars. They quit using them sometime in the production year. Not seen on most survivor cars unless they are early build dates. However, I have a 70' 318 car built in Hamtramck with a SPD of 209 that has them. No rhyme or reason why. It's a mystery as to why a few got them or not. See the thread below for more info. LINKY Mystery solved, thanks! Mine is a pretty early October '69 built car so this makes sense. Now to try yo track some of those brackets down... No those L brackets do not go in those holes. Not sure what there for.
[Re: Challenger 1]
#2358669
08/23/17 05:36 PM
08/23/17 05:36 PM
Posts: 318 Iowa
ratroaster
Iowa
No those L brackets do not go in those holes. Not sure what there for. How so? Did you read the thread that I linked?
[Re: challenger70]
#2358671
08/23/17 05:40 PM
08/23/17 05:40 PM
Posts: 318 Iowa
ratroaster
Iowa
I wouldn't worry about it if I was you. Those holes are empty in 90% of '70 Challengers.
[Re: ratroaster]
#2359057
08/24/17 11:50 AM
08/24/17 11:50 AM
challenger70
Berwyn, IL
I wouldn't worry about it if I was you. Those holes are empty in 90% of '70 Challengers. I am not worried about it, but I like the hunt for rare/hard to find stuff though I see now that there are 2 for each side for 4 total. 1 more thing to keep an eye out for at swaps/ebay.
[Re: Challenger 1]
#2359060
08/24/17 11:53 AM
08/24/17 11:53 AM
challenger70
Berwyn, IL
These threaded holes were used for 2 more L shaped brackets that only came on a few cars. They quit using them sometime in the production year. Not seen on most survivor cars unless they are early build dates. However, I have a 70' 318 car built in Hamtramck with a SPD of 209 that has them. No rhyme or reason why. It's a mystery as to why a few got them or not. See the thread below for more info. LINKY Mystery solved, thanks! Mine is a pretty early October '69 built car so this makes sense. Now to try yo track some of those brackets down... No those L brackets do not go in those holes. Not sure what there for. They must have removed the holes for them (or you filled them in) by '71 I don't see them in those pictures. They are just outside of each side of where the leafspring meets the panel.
