should i do it? #2357928
08/22/17 12:55 AM
08/22/17 12:55 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i recently bought a 2003 dakota 3.9 v6 and 3.55 rear end,it shifts out of overdrive at the least hill and a big hill it goes into second,im thinking it needs a 3.9 rear axle with a suregrip,thats what i have in my old 92 and its great,will i lose much if any in fuel mileage?,on flat ground maybe?,but goin up and down hills it just might at least stay in 3rd gear,its actually a little heavier than my 92 but has the same drivetrain except the computer shifts the 03
what say you??
my ladder of success is missing some rungs
Re: should i do it? [Re: rhad] #2357932
08/22/17 12:59 AM
08/22/17 12:59 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
might be throttle psi adjustment ?
Re: should i do it? [Re: rhad] #2358064
08/22/17 12:19 PM
08/22/17 12:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 3.9's are dogs. I don't see what gearing down will get you. A 3.55 pulling up hill in second vs a 3.9 pulling uphill in 3rd, your rpm will probably be pretty close to the same. I think the 03 is heavier than you let on...
