Re: No start...Positive battery cable is hot to touch...
[Re: ksat]
#2356650
08/19/17 04:57 PM
08/19/17 04:57 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
it's hot because of constant heavy load from cranking, or a bad connection at the battery post - clean both posts.
it's not staring because;
no fuel in carb.
no spark at plugs due to;
broken wire, dist not working properly, bad or weak coil.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: ksat]
#2356682
08/19/17 06:02 PM
08/19/17 06:02 PM
amxautox
What gauge is the battery cable? Maybe it's got a bad contact within the cable end.
Tom
author unknown
[Re: ksat]
#2356757
08/19/17 08:10 PM
08/19/17 08:10 PM
Posts: 5,954 ohio
ruderunner
ohio
The hot spot is the bad connection. Probably where the wire meets the clamp.
Seen lots of aftermarket cables with poor connection at the clamp. New or not. 2 seconds of cranking shouldn't get the cable warm, let alone hot.
Angry white pureblood male
[Re: ksat]
#2356801
08/19/17 09:08 PM
08/19/17 09:08 PM
amxautox
That would be a bad cable.
Take it off, check the resistance with an ohm meter. Try another cable.
Tom
author unknown
[Re: ksat]
#2356814
08/19/17 09:23 PM
08/19/17 09:23 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
High starter draw? Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: ruderunner]
#2356816
08/19/17 09:29 PM
08/19/17 09:29 PM
Challenger 1
Cincinnati, Ohio
Seen lots of aftermarket cables with poor connection at the clamp. New or not. 2 seconds of cranking shouldn't get the cable warm, let alone hot. For sure one of your cables are bad.
[Re: Challenger 1]
#2356870
08/19/17 11:41 PM
08/19/17 11:41 PM
RapidRobert
I'd think a good/charged battery would be higher than 12.6V. what is the cranking voltage?
