Whats the correct 1968 426 hemi p/s pump and pulley? #235612
02/25/09 02:22 AM
02/25/09 02:22 AM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
I have 3 different p/s pumps and pullies. The 426 hemi 1968 and later are different from 1969 - newer. What type is the correct, saginaw, fed mog or trw? also is the pulley the smaller solid or larger pulley with 3 openings. Any help or pics is greatly appreciated. Thanks Tim pm me here or email at timtlyons@sbcglobal.net
Re: Whats the correct 1968 426 hemi p/s pump and pulley [Re: ts70rt] #235613
02/25/09 10:07 AM
02/25/09 10:07 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Hemi's had the federal pump all the way to 70 , 71 ??? . 68 older used the waterpump pulley that is the same as the B/RB so I would assume that the pump pulley is the same as B/RB 68 /older ?
Re: Whats the correct 1968 426 hemi p/s pump and pulley [Re: JohnRR] #235614
02/25/09 01:31 PM
02/25/09 01:31 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Picture of 68 Hemi P/S pump
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Whats the correct 1968 426 hemi p/s pump and pulley [Re: 6T9Hemi] #235615
02/27/09 01:06 AM
02/27/09 01:06 AM
ts70rt Offline OP
ts70rt  Offline OP
THANKS ALOT. Tim
