Vac. signal at booster #2355732
08/17/17 10:16 PM
08/17/17 10:16 PM
Batavia,Ohio,
Moparmick Offline OP
Batavia,Ohio,
How much vac. is required for proper operation of a brake booster on 71 charger w/383 auto 4bbl?
Re: Vac. signal at booster [Re: Moparmick] #2355764
08/17/17 10:59 PM
08/17/17 10:59 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Depending on the booster and other things about 12"hg but as high as 14" in my best guess.
Re: Vac. signal at booster [Re: Moparmick] #2355804
08/18/17 12:00 AM
08/18/17 12:00 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
My power brakes work fine with 8Hg
The only Carbs I care about are under the hood!
Re: Vac. signal at booster [Re: Moparmick] #2356837
08/19/17 10:21 PM
08/19/17 10:21 PM
Batavia,Ohio,
Batavia,Ohio,
anybody else ?
