block prep #2355038
08/16/17 07:52 PM
08/16/17 07:52 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
do the gen111 have to be prepped like the older blocks,such as line hone and decked or are they made close enough for a performance build without that?
Re: block prep [Re: bonefish] #2355280
08/17/17 04:12 AM
08/17/17 04:12 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I had to have mine line-honed on the mains, bored and honed on the cylinders with a deck plate, and decked for smoothness. It needed the same type of work any other block of any make/vintage that I built needed. The deck surface finish is key because of the MLS head gaskets the G3 engines use...
SuperBeast
An enforcer for the Mopar Mafia!
Re: block prep [Re: sycboi] #2355312
08/17/17 09:31 AM
08/17/17 09:31 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Thanks,thats kinda what i thought.i was just thinkin with all the new tech they could get things a bit closer.
