Re: New Six pack fuel lines leaking
[Re: A727Tflite]
#2354498
08/15/17 10:25 PM
08/15/17 10:25 PM
Posts: 2,385 White Plains, NY
VCODE
White Plains, NY
Hi Glenn, This is what you do. Permatex makes a high temp sealant # 59235. Use this it works. Let it dry for at least a day or two before you run it with gas. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#2354506
08/15/17 10:43 PM
08/15/17 10:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hi Glenn, This is what you do. Permatex makes a high temp sealant # 59235. Use this it works. Let it dry for at least a day or two before you run it with gas. Bob Pretty sure they are flare fittings, in which case sealant is useless.
[Re: 62maxwgn]
#2354544
08/15/17 11:52 PM
08/15/17 11:52 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I ran into that issue last year when I was putting my T/A together. My lines were leaking like crazy at the carbs, and nothing seemed to help, until my engine builder told me to put some grease on the threads before installing the lines. I never thought that would work, but was running out of ideas. Greased the threads up with red grease, installed and tightened them, fired up the engine, and dry as a bone!
[Re: glenngomango]
#2354558
08/16/17 12:18 AM
08/16/17 12:18 AM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
The seal takes place between the inverted tubing flare and the corresponding "male" flare in the fitting. If you have done the "loosen / tighten" routine more than 3 or more times, 1. Either the flare on the tube is bad, 2. The nut is bad, 3. The "seat" in the fitting is bad, 4. Or there is debris preventing the seal. Disassemble, inspect the flare on the tube and seat in the fitting. Your problem should become apparent.
[Re: glenngomango]
#2354708
08/16/17 10:26 AM
08/16/17 10:26 AM
VCODE
White Plains, NY
Glenn, where did your get that trouble shooting trophy? I was in the 1969 Chrysler/Plymouth contest in New York. Bob
[Re: Mastershake340]
#2354720
08/16/17 10:59 AM
08/16/17 10:59 AM
Challenger 1
Cincinnati, Ohio
I ran into that issue last year when I was putting my T/A together. My lines were leaking like crazy at the carbs, and nothing seemed to help, until my engine builder told me to put some grease on the threads before installing the lines. I never thought that would work, but was running out of ideas. Greased the threads up with red grease, installed and tightened them, fired up the engine, and dry as a bone! Grease or oil is best and should always be used on flare fittings to allow you to get them tight. IMO never use teflon tape anywhere on a fuel system, never. Because it is near impossible to get all the little pieces out when you take it apart. Plus it looks like sh!t and tells everyone you don't understand flare fittings.
[Re: sogtx]
#2354873
08/16/17 02:22 PM
08/16/17 02:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Since theres inverted flares on these , the threads dont Really hold any pressure Listen to Mr Bill 62 maxwagon This is the proper way - if you cant titen them properly
Generally the use of copper is avoided with gasoline use, as the gasoline with slowly dissolution the copper and actually "plate" the fuel system/carbs/etc with copper thru an electroless process
[Re: DAYCLONA]
#2354878
08/16/17 02:26 PM
08/16/17 02:26 PM
TJP
Omaha Ne
Generally the use of copper is avoided with gasoline use, as the gasoline with slowly dissolution the copper and actually "plate" the fuel system/carbs/etc with copper thru an electroless process not to mention you have now doubled the sealing surfaces and potential for leaks
[Re: TJP]
#2354983
08/16/17 05:51 PM
08/16/17 05:51 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Generally the use of copper is avoided with gasoline use, as the gasoline with slowly dissolution the copper and actually "plate" the fuel system/carbs/etc with copper thru an electroless process not to mention you have now doubled the sealing surfaces and potential for leaks Not really,neither of these have leaked with stainless lines since I finished them,the bird in 92 and the other in 2011,both have been apart numerous times,put the lines on and never had a leak problem and I have yet to see any sign of copper plating anywhere.You do as you see fit,I'll stick with what works for me!
[Re: sogtx]
#2355534
08/17/17 04:29 PM
08/17/17 04:29 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Wow those are kool where can one get them?
[Re: glenngomango]
#2355624
08/17/17 07:38 PM
08/17/17 07:38 PM
Posts: 291 St. Louis
Imrare
St. Louis
I will provide my solution to the "leaking lines" on a 6-pack. I resorted to using a small black O-ring that was just small enough to fit inside the Carburetor nut (it the same diameter as the flared fuel line) that the fuel line bolts to. Because the O-ring is actually sealing against the fuel line "flare" and the Carb nut, you can't tighten it real tight like you normally would or it will destroy the O-ring. I tightened it "extra snug". I did this as a "last resort" when I couldn't get my new lines to seal. It has been 2 years since this fix and I haven't had to touch them and they are not leaking.
