Which roller rockers? #2353419
08/14/17 12:42 AM
08/14/17 12:42 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I plan to order a set of 1.5 ratio roller rockers for my 470 pump gas motor soon and would like to know if one or the other is better between Harland Sharp and Comp Pro Magnums. I'll be running a solid flat tappet cam and although I'm not quite sure of the exact size yet it will be in the .560 to .590 lift range.
Re: Which roller rockers? [Re: 440mopar] #2353420
08/14/17 12:44 AM
08/14/17 12:44 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Harland Sharp... my .02
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Which roller rockers? [Re: 440mopar] #2353424
08/14/17 12:52 AM
08/14/17 12:52 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
A few years ago I was trying to decide between those exact two rockers and decided to go with the Harland Sharps because the Pro Magnums (IIRC) were bushed. The Harland Sharps have been great so far, but be sure to look them over before you install them if you decide to go that direction. The ones that I bought had lots of shavings in the shaft and weren't cleaned up very well.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Which roller rockers? [Re: 440mopar] #2353430
08/14/17 01:03 AM
08/14/17 01:03 AM
Washington
madscientist Offline
Washington
Pro magnum.
Re: Which roller rockers? [Re: 440mopar] #2353435
08/14/17 01:10 AM
08/14/17 01:10 AM
AndyF Offline
AndyF  Offline
For a street motor I'd probably lean towards a steel or iron rocker arm rather than aluminum but it might not really matter too much.
At that lift the old Isky or Crane nodular rocker arms should work fine if you can find a nice set.
Re: Which roller rockers? [Re: 440mopar] #2353451
08/14/17 01:50 AM
08/14/17 01:50 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I have two sets of crane golds. 1.5 or 1.6. PM me.
Re: Which roller rockers? [Re: 440mopar] #2353462
08/14/17 05:18 AM
08/14/17 05:18 AM
I have used a bunch of different brands and type of rocker arms in my racing and street cars, Harland Sharp are good for both up
As far as your deal I would look at using the Harland Sharp 1.60 ratio rockers and buy a cam designed for that ratio up scope
BB Mopars, especially stroker motors with decent heads, really need all the air and fuel you can feed them to make the best power up
Re: Which roller rockers? [Re: 440mopar] #2353484
08/14/17 09:02 AM
08/14/17 09:02 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
How do Hughes rockers line up with those 2 ?
Re: Which roller rockers? [Re: varunner] #2353581
08/14/17 12:59 PM
08/14/17 12:59 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Re: Which roller rockers? [Re: 440mopar] #2353587
08/14/17 01:04 PM
08/14/17 01:04 PM
P
Porter67 Offline
Porter67  Offline
P
If thats all you ever plan to do, use the comps, you will never hurt them and never worry about too much oil up top or needles in your motor.
If you plan to go heavy roller, high rpm HS.
Money is money I dont spend more then I need to, but thats just me.
Even the $500 china SS rockers that people use and ive heard nothing bad about would work in your case, not the al/needle ones the SS bushed units.
Re: Which roller rockers? [Re: 440mopar] #2353649
08/14/17 03:03 PM
08/14/17 03:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Wasting my time.
Boffin Emeritus
Re: Which roller rockers? [Re: 440mopar] #2354656
08/16/17 04:20 AM
08/16/17 04:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been running these Hughes roller tip rockers since June 2011 and have never had any problems at all. I run a solid flat tappet cam thats .585 and .592 lift. These have worked great for me and hold the adjustment just fine. Ron
Re: Which roller rockers? [Re: 383man] #2354842
08/16/17 01:44 PM
08/16/17 01:44 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
I think I'm going to buy a set of the Hughes rockers. It seems like Andy said these were the best available in terms of being the correct length.
Re: Which roller rockers? [Re: 440mopar] #2354892
08/16/17 03:23 PM
08/16/17 03:23 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Hughes 1.5 been good on my flat tappet
5 years
6,000 miles
And about 100 passes
Re: Which roller rockers? [Re: 440mopar] #2354921
08/16/17 04:08 PM
08/16/17 04:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I've used the Comps on a flat tappet cam and now use HS on a .680-.660 solid roller...........
Re: Which roller rockers? [Re: 440mopar] #2355240
08/17/17 01:39 AM
08/17/17 01:39 AM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Hughs 1.5 have worked great with BB eddies and FT solids. They hold an adjustment very well and are great quality parts. I just didn't need the T&D's / Jesels and the cost. My cam isn't much over .550. I ran Isky and Crane iron rockers for many years without any probs. but I think Hughs were a step up in tuning and overall smoothness when I changed over the rocker assy only at that time.
Re: Which roller rockers? [Re: 440mopar] #2355246
08/17/17 01:52 AM
08/17/17 01:52 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I agree, Hughes rockers are great, everytime i check adjustment they are spot on .
1963 Plymouth Max Wedge
1971 Barracuda
Re: Which roller rockers? [Re: 440mopar] #2355318
08/17/17 09:56 AM
08/17/17 09:56 AM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Just curious...if you're buying new rockers, why not go with 1.6 ratio to gain some lift. It seems basically free. My next set will be 1.6. Good luck.
