Re: RINGS
[Re: 493_DART]
#2352276
08/11/17 04:03 AM
08/11/17 04:03 AM
RapidRobert
I have a NIB set of 315-0029 perfect circle single moly 30 over 440 rings 1/16 1/16/ 3/16. $49 to your door. email me. box is ratty/rings were out of the box & are perfect.
Re: RINGS
[Re: 493_DART]
#2352492
08/11/17 05:46 PM
08/11/17 05:46 PM
dogdays
Standard Olds 403 is 4.351, standard Ford 460 is 4.360 Cadillac 472/500 60 over is 4.360 this may expand your search area a little. R.
Re: RINGS
[Re: RapidRobert]
#2352499
08/11/17 06:00 PM
08/11/17 06:00 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I have a NIB set of 315-0029 perfect circle single moly 30 over 440 rings 1/16 1/16/ 3/16. $49 to your door. email me. box is ratty/rings were out of the box & are perfect. thanks--but i just need 1 hole.
Re: RINGS
[Re: 493_DART]
#2352525
08/11/17 06:31 PM
08/11/17 06:31 PM
Posts: 4,457 Washington
madscientist
Washington
I have a NIB set of 315-0029 perfect circle single moly 30 over 440 rings 1/16 1/16/ 3/16. $49 to your door. email me. box is ratty/rings were out of the box & are perfect. thanks--but i just need 1 hole. Doesn't sound like a bad deal. Not a lot of money and then you'll have spares.
Re: RINGS
[Re: madscientist]
#2352607
08/11/17 09:37 PM
08/11/17 09:37 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I have a NIB set of 315-0029 perfect circle single moly 30 over 440 rings 1/16 1/16/ 3/16. $49 to your door. email me. box is ratty/rings were out of the box & are perfect. thanks--but i just need 1 hole. Doesn't sound like a bad deal. Not a lot of money and then you'll have spares. X2. Summit's $13 ring set is going to cost you $23 unless you spend $100. You might as well just buy Rapidrobert's ring set. You'll really kick yourself in the butt if you buy just one and end up needing another set.
Re: RINGS
[Re: sgcuda]
#2352638
08/11/17 11:10 PM
08/11/17 11:10 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a NIB set of 315-0029 perfect circle single moly 30 over 440 rings 1/16 1/16/ 3/16. $49 to your door. email me. box is ratty/rings were out of the box & are perfect. thanks--but i just need 1 hole. Doesn't sound like a bad deal. Not a lot of money and then you'll have spares. X2. Summit's $13 ring set is going to cost you $23 unless you spend $100. You might as well just buy Rapidrobert's ring set. You'll really kick yourself in the butt if you buy just one and end up needing another set. That's why I keep a short list in my wish list. I always like to keep spare gaskets or maybe a fitting for an upcoming project. 100.00 isn't hard to spend in the candy store. Lol
Re: RINGS
[Re: madscientist]
#2352647
08/11/17 11:27 PM
08/11/17 11:27 PM
RapidRobert
Doesn't sound like a bad deal. Not a lot of money and then you'll have spares. I couldn't agree more!
