The thing is the plugs look fairly clean, so I don't fully believe the AFR at idle has been 11:1 for the past 3 years.
Tune for driveabilty, efficiency and power. To rephrase another persons post, use the AFR numbers as a tool rather than target. As the car is an automagic, the vac reading
in gear can also be used as another tool.
Typical 4stroke piston engines will idle (hot) most efficiently from 13 to 14, but can be a little higher or lower. An engine with a hot cam has overlap at idle that reduces combustion temperatures and also generally has lots of exhaust dilution. Because of these factors they tend to need more fuel to air than a combustion event with higher compression and less exhaust.
These AFRs are from the graphs in
AFR Ratio Studies. See the fig 12 from Larew and 5-8 from Taylor along with Tuner's comments on hot rodded engines.
This thread may also be of interest:
Combustion Products post
