ADDING A VOLT METER #2346031
07/31/17 12:58 AM
07/31/17 12:58 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I want to install a volt meter in one of my Magnums, now, if I wire it at or from the (+) and (-) posts, will it run down the battery? Or, is there a better way to wire one up simply?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: ADDING A VOLT METER [Re: Magnumguy] #2346040
07/31/17 01:15 AM
07/31/17 01:15 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You want a switched 12v source or it will always draw on the battery.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: ADDING A VOLT METER [Re: Magnumguy] #2346044
07/31/17 01:39 AM
07/31/17 01:39 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Usually switched. Could plug it into the accessory terminal on the fuse box if it has one.
The load a voltmeter puts on a battery is very, very small. Hold for a few weeks? Sure. A few months? Don't know.
The one in my 72 SSP is taped from the ammeter gauge so it is hot all the time but the longest it has gone without driving is about two weeks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: ADDING A VOLT METER [Re: Magnumguy] #2346049
07/31/17 01:54 AM
07/31/17 01:54 AM
S.E.Ohio
S.E.Ohio
This car's going to be a semi-daily driver, so setting long periods is highly unlikely. Wasn't sure where I could draw juice from so as to not run battery down.
Thanks.
Re: ADDING A VOLT METER [Re: Magnumguy] #2346115
07/31/17 10:43 AM
07/31/17 10:43 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I plugged one into my cig lighter.
Re: ADDING A VOLT METER [Re: Challenger 1] #2346260
07/31/17 04:30 PM
07/31/17 04:30 PM
dogdays Offline
dogdays  Offline
So did I. I think I paid $12 at a parts store. Innova 7421.
R.
Re: ADDING A VOLT METER [Re: Magnumguy] #2346304
07/31/17 06:03 PM
07/31/17 06:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Got a digital one also. Works fine and was cheap.
