Hood clearance issues with schumacher conversion mounts
#2343973
07/26/17 10:59 PM
07/26/17 10:59 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Has anybody ran into hood clearance issues with the Schumacher hemi conversion mounts? I installed them in my cuda and now the air cleaner wont fit under the hood. The motor has a stock Chrysler intake and stock six pack style hemi air cleaner.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Hood clearance issues with schumacher conversion mounts
[Re: 73cuda340]
#2344388
07/27/17 04:20 PM
07/27/17 04:20 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
I used them on my Road Runner when swapping a Hemi onto the 3783 k-frame. The engine was raised about 1/4". I had heard about height changes and measured the centerline of crank to lip of k frame before pulling engine. When I ordered my TTi Headers, their directions indicate that conversion mounts raise the engine about the same amount. I went with a cross ram and cut my hood, so I wasn't concerned about clearance on carbs or intake. But the TTi headers fit great.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: DougR]
#2344401
07/27/17 04:46 PM
07/27/17 04:46 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I put a 426 Hemi in a 1970 Challenger on a BB K-frame with a set of adapters I developed myself. (I are an engineer.) They keep the engine at the correct position. John Arruzza sells them now. I have no experience with Schumacher Hemi mounts. I thought Arruzza was out of business?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 73cuda340]
#2344687
07/28/17 03:59 AM
07/28/17 03:59 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I had the issue when installing a 5.9 Magnum in my '68 A-Body. Ended up getting the stock rubber ones from them and using their torque tube.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: astjp2]
#2345025
07/28/17 09:39 PM
07/28/17 09:39 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I put a 426 Hemi in a 1970 Challenger on a BB K-frame with a set of adapters I developed myself. (I are an engineer.) They keep the engine at the correct position. John Arruzza sells them now. I have no experience with Schumacher Hemi mounts. I thought Arruzza was out of business? From his website; http://www.arruzzahighperformance.com/Parts/Parts.html
