Page 12 of 34 1 2 10 11 12 13 14 33 34
Re: Starting to work on the Duster [Re: AndyF] #2502917
05/31/18 09:50 PM
05/31/18 09:50 PM
AndyF Offline OP
AndyF  Offline OP
No I don't think a PCV valve adds any power, but on a street car it can help keep the engine clean. I'm going to try to see if I can get it set up to work on this engine but I might fail. I figure that starting with an adjustable PCV gives me a fighting chance of making it work.
Re: Starting to work on the Duster [Re: AndyF] #2502929
05/31/18 10:38 PM
05/31/18 10:38 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Thanks, I have a good a document I found on an adjustable PVC. It' too big to upload though. PM me and I can email it to anyone who'd like to see it.
Re: Starting to work on the Duster [Re: AndyF] #2509640
06/17/18 03:36 PM
06/17/18 03:36 PM
AndyF Offline OP
AndyF  Offline OP
Fuel system article is published on the Hot Rod website: http://www.hotrod.com/articles/dustbin-duster-fuel-system-solution/
Re: Starting to work on the Duster [Re: AndyF] #2509869
06/18/18 09:55 AM
06/18/18 09:55 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Nice progress. Loaded with new ideas for the rest of us!
2 kids and a dog
Re: Starting to work on the Duster [Re: AndyF] #2575624
11/07/18 11:52 PM
11/07/18 11:52 PM
AndyF Offline OP
AndyF  Offline OP
Got the Doctor Diff Viper kit hung on the front. Brake lines are run and the suspension is back in the car. Getting ready to take the car over to the chassis shop next week for some work. New roll bar, some tin work, mount the dash, fix the core support, etc.
Re: Starting to work on the Duster [Re: varunner] #2575674
11/08/18 01:21 AM
11/08/18 01:21 AM
Washington
madscientist Offline
Washington
Originally Posted By varunner
Very nice work Andy. Question, have you covered in another thread what your thinking is concerning the pvc valve ? I see it's adjustable and I'm wondering if it adds horsepower which you'd see on the time slip. thanks
Originally Posted By AndyF
Got some patch panels welded in and finished running the plumbing for fuel and trans cooler. Now I'm working on the wiring as I get time.
I have that Wagner PCV valve that I'm going to do some testing with. I'm not using it like a conventional PCV and Wagner knows it.
I've done a bit of testing with it, but not enough to say what I'm doing will work.
Re: Starting to work on the Duster [Re: AndyF] #2582670
11/25/18 02:16 AM
11/25/18 02:16 AM
AndyF Offline OP
AndyF  Offline OP
The new core support from US Car Tool is installed. I tweaked the design a bit so it would fit the C body radiator and I added dimple die hole on each side.
Re: Starting to work on the Duster [Re: AndyF] #2582671
11/25/18 02:19 AM
11/25/18 02:19 AM
AndyF Offline OP
AndyF  Offline OP
The new rollbar is in place. We put an X brace in the rear down tubes as well as the down bars behind the seat. The roll bar is Chrome Moly. The chassis guy did a really nice job on it. He also built new tin for the back seat area but it hasn't been finished up yet.
Re: Starting to work on the Duster [Re: AndyF] #2582776
11/25/18 01:17 PM
11/25/18 01:17 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Which motor are you going to install since you sold the 470
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Starting to work on the Duster [Re: AndyF] #2582778
11/25/18 01:20 PM
11/25/18 01:20 PM
AndyF Offline OP
AndyF  Offline OP
I'm going to put the 512 out of my Coronet in the Duster. I have a 426W based stroker that is going into the Coronet.
Re: Starting to work on the Duster [Re: AndyF] #2583110
11/26/18 02:52 AM
11/26/18 02:52 AM
AndyF Offline OP
AndyF  Offline OP
With the new core support it looks like I have enough room to run a stock water pump and a clutch fan. Tight, but it all clears. Or I can ditch the clutch fan and run a nylon or aluminum mechanical fan. I'll have to take a look at some options.
Re: Starting to work on the Duster [Re: AndyF] #2583151
11/26/18 10:57 AM
11/26/18 10:57 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Looking good Andy, lovin this build !
Re: Starting to work on the Duster [Re: AndyF] #2583155
11/26/18 11:17 AM
11/26/18 11:17 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I also enjoy the car craft articles you do, good reading
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Starting to work on the Duster [Re: AndyF] #2583186
11/26/18 01:13 PM
11/26/18 01:13 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Nice work. One of the perks of using a motor plate, you get to mock up your cooling system.
2 kids and a dog
Re: Starting to work on the Duster [Re: TonyS451] #2583242
11/26/18 03:15 PM
11/26/18 03:15 PM
AndyF Offline OP
AndyF  Offline OP
Yeah I was thinking I needed to drop the engine into the car to check the clearances then I realized that I could just bolt the motor plate in and use that. Saved me a lot of time.
Re: Starting to work on the Duster [Re: AndyF] #2583245
11/26/18 03:16 PM
11/26/18 03:16 PM
AndyF Offline OP
AndyF  Offline OP
Here is a shot of some of the extra bracing added to the front of the car. We also installed the torque boxes but those are a little harder to get a shot of.
Re: Starting to work on the Duster [Re: AndyF] #2583323
11/26/18 06:30 PM
11/26/18 06:30 PM
I like that up
Are you thinking of marketing them? If so I'll take a pair thumbs
Re: Starting to work on the Duster [Re: AndyF] #2583370
11/26/18 08:00 PM
11/26/18 08:00 PM
AndyF Offline OP
AndyF  Offline OP
Re: Starting to work on the Duster [Re: AndyF] #2583383
11/26/18 08:31 PM
11/26/18 08:31 PM
fullmetaljacket Offline
That's fast becoming a work of art Andy.
Nice stance that pup has.
Re: Starting to work on the Duster [Re: TonyS451] #2583427
11/26/18 10:31 PM
11/26/18 10:31 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Sometimes the simplest ideas are brilliant! I was thinking I would mock up cooling on my g3 swap while I was test fitting a bare block. Since I'm using a motor plate, AndyF has shown me the light! At the same time, I'm feeling like...."Duh, Doug".
