1966 Coronet Fuel Line Routing At Shock Crossmember? #2341804
07/23/17 02:07 AM
07/23/17 02:07 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Anybody got a picture of how the fuel line routes across the rear hump and next to the shock cross member? The old line I'm replacing was cut way back by the PO and I'm having some confusion on the routing path up next to the shock cross member. 5/16" line. Thanks!
Re: 1966 Coronet Fuel Line Routing At Shock Crossmember? [Re: Scott58] #2342047
07/23/17 05:21 PM
07/23/17 05:21 PM
can use route it where it nestles the neatest (if you are bending new material) or are you wanting to exactly duplicate the OE routing?
Re: 1966 Coronet Fuel Line Routing At Shock Crossmember? [Re: RapidRobert] #2342102
07/23/17 07:53 PM
07/23/17 07:53 PM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
It's a pre-bent line. I think I figured it out.
