Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2335303
07/11/17 01:38 PM
07/11/17 01:38 PM
AndyF Offline
AndyF  Offline
Looks to me like you bought the wrong alternator. Check your part numbers, I don't think you ordered the part number that the instructions say to use.
Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2335320
07/11/17 02:04 PM
07/11/17 02:04 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
It's the same physical size just a higher amperage.. I checked that first
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: AndyF Motorplate/alt questions [Re: AndyF] #2335323
07/11/17 02:09 PM
07/11/17 02:09 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Originally Posted By AndyF
That alternator is too big to fit. Look at the alternator in my picture, it is much smaller.
it's the same alternator just not black and have the upper mount shaved. Only difference is mine is 100 amp.
Re: AndyF Motorplate/alt questions [Re: a493demon] #2335367
07/11/17 03:46 PM
07/11/17 03:46 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Originally Posted By a493demon
I have the DMI bracket .
But I got the plate that didn't have the cut out so I cut it myself.
Same here but I had to cut down my bracket slightly due to it hitting my tubular K frame (Not the factory K frame).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: AndyF Motorplate/alt questions [Re: 6PKRTSE] #2335550
07/11/17 10:18 PM
07/11/17 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
when I went to fit up my east coast mini there was no way it was going to fit in the little tiny space by the crank trigger, it hit every where, ended getting the ultra mini and was able to get it where I wanted it then came the mount top mount I drilled the lower bar or the AR plate that had the scallops and tapped it 3/8-16 and made a adjuster bar that I mounted to the side of the frame works great plenty of adjustment, if I can get a chance I will take a pic of it and try to get it posted on here.
Re: AndyF Motorplate/alt questions [Re: dartman366] #2335571
07/11/17 10:44 PM
07/11/17 10:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
here is a pic of the lower mount, you cannot see the upper part but it is just bolted to the bottom of the plate and spaced to align to the drive mandrel pulley.
Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2335581
07/11/17 10:53 PM
07/11/17 10:53 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i'll send you a pic on facebook of mine
Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2335620
07/11/17 11:43 PM
07/11/17 11:43 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
But the real burning question is why the logo is on the backside...
I want my fair share
Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2336201
07/12/17 10:38 PM
07/12/17 10:38 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
I got it to clear so far. Moved the braket up to the next hole, The upper bolt now goes through the web opening so I made a 1"x.25 aluminum washer for support. The adjuster braket will come off tabs on the frame rail.
Thanks for your guys inputs.
MOPARS TO THE FRONT
Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2341397
07/22/17 11:07 AM
07/22/17 11:07 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Al or any other members do you have a part number on the alt you guys are using on the dragster I'm getting ready to start final assembly next week and still need the smallest alt I can find with atleast 100 amps of current.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: AndyF Motorplate/alt questions [Re: HOTMOPR] #2341424
07/22/17 12:26 PM
07/22/17 12:26 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
MOPARS TO THE FRONT
Can you make a disc the size of the hole to support the bolt and slot it to fit the bolt size?Just an idea to make it stronger.
Re: AndyF Motorplate/alt questions [Re: SomeCarGuy] #2341429
07/22/17 12:42 PM
07/22/17 12:42 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thought that Logo being on back side was silly as well, but it is what it is. I use the DMI alt mount with a toyota denso alt and it fit just fine. Not using a crank trigger thou. Had to buy 4 different serp belts til i found the one with good adjustability.
