Adding endplay adjusters to truck Dana 60 #2339531
07/19/17 06:03 AM
07/19/17 06:03 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
How complicated is it to add endplay adjusters to a converted truck Dana 60? I have a truck Dana that I would like to convert to a car Dana using either 8 3/4 housing ends, 8 3/4 ends with big Ford bearings or Ford ends. I want to use tapered bearings and would like to have an adjuster like on the 8.75.
Re: Adding endplay adjusters to truck Dana 60 [Re: DGS] #2339540
07/19/17 07:23 AM
07/19/17 07:23 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
You either need a suregrip with the cross pins drilled for the thrust buttons, or if you use the big ford bearings then you don't need end play adjusters, cause the Set 20 bearings don't use em.
I bought my axles for my Dana from Dr Diff with the Ford style Set 20 tapered roller bearings, along with housing ends for em that still had the mopar backing plate pattern so i could use my brakes.
Re: Adding endplay adjusters to truck Dana 60 [Re: DGS] #2340062
07/19/17 11:34 PM
07/19/17 11:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Big ford tapered roller wheel bearings are NON-adjustable.
Re: Adding endplay adjusters to truck Dana 60 [Re: DGS] #2340155
07/20/17 04:07 AM
07/20/17 04:07 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Great, that makes things much easier. I think the housing ends with the Mopar pattern and Ford bearing are from Strange.
Re: Adding endplay adjusters to truck Dana 60 [Re: DGS] #2340408
07/20/17 03:56 PM
07/20/17 03:56 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you use the torino ends, then you can use the explorer discs in the rear for uber cheap, and they have a parking brake that is super simple to adopt.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
