Small block flywheel identifcation ? #2339245
07/18/17 06:18 PM
07/18/17 06:18 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Got a flywheel with a car my son bought. Have 2 choices of motors I may use. How do I identify if the flywheel is a internal or external flywheel? Was down this road 40 years ago and had to tear everything apart and get it balanced, don't want to do that again. Looked for a part number on it but couldn't find one. Any help? one motor is a 77 318 , the other is a 72 340.probaly going to use the 318 for now cause the 340 needs a rebuild and he's on a budget.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Small block flywheel identifcation ? [Re: hulmule] #2339250
07/18/17 06:26 PM
07/18/17 06:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A pic of the crankshaft side of the flywheel would help.
Re: Small block flywheel identifcation ? [Re: John_Kunkel] #2339410
07/18/17 11:42 PM
07/18/17 11:42 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
[img]72 340 flywheel[/img]
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Small block flywheel identifcation ? [Re: hulmule] #2339413
07/18/17 11:43 PM
07/18/17 11:43 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
how do I post a picture?
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Small block flywheel identifcation ? [Re: hulmule] #2339667
07/19/17 12:45 PM
07/19/17 12:45 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
When you click on 'Reply' and the reply dialog box comes up, click on the 'File Manager' link just below the message box. The dialog box for adding photos will open. Then click 'Browse' and find the photo on your PC. Click on your your photo. The name of your photo will appear between the 'Browse' and 'Add File' buttons. Click on 'Add File' and your photo name will be at the top of the dialog box. If this is the only photo, click on "Done Adding Files". Your photo is now an attachment. Hope this helps.
Re: Small block flywheel identifcation ? [Re: 6PakBee] #2339871
07/19/17 05:50 PM
07/19/17 05:50 PM
dogdays Offline
dogdays  Offline
Bigblocks and smallblocks use the same six bolt flywheels, so there are more possibilities to ponder.
ANY 318 is internally balanced as is any 5.2Mag, 350B, 361, 383RB, forged crank 383B, 413, and many 440s.
Most flywheels of a specific size had the same casting number, the one that's on the flywheel. Nothing to be told from that.
The factory unbalanced the flywheels the same way they showed us in the DC or MP engine books. There should be a diagram here somewhere. All this was done on the engine side of the flywheel. That's why the picture is needed.
R.
Re: Small block flywheel identifcation ? [Re: dogdays] #2339888
07/19/17 06:28 PM
07/19/17 06:28 PM
when you find the (MP) picture you will need to find someone who knows trigonometry to do the math to pinpoint the exact location of where to drill the holes to unbalance it.
