Re: brake lines 8 3/4 rear
[Re: DPelletier]
#233990
02/24/09 09:57 AM
02/24/09 09:57 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I had the same exact problem with my 71 Cuda. The lines I got from Fine Lines did not line up with the block mounted very close to the pumpkin. The lines wanted to mount in the middle of the driver side tube. Turns out the 8 3/4 was from an earlier B body. Bob from Fine Lines swap sets and now they fit perfect.
Well, it certainly seems the concensus is I have the wrong housing. I WAS just going to order earlier B body lines, but now I can't help but wonder if I have an E body rear!
Anybody have a link to a list of rear end widths?
And thanks to everyone for the responses; much appreciated.
this ???
from the tech archive
Dave , I can measure the length on a 69 housing to the hole location tonight when I get home .
As far as changing the line , you might want to see if a 70 has a different body line FIRST . If it does then that means the location where the flex line connects may be in a different location ??? I ended up redrilling the A body axle I had to put it in the proper location and just Loctited a socket head set screw in the original hole .
[Re: DPelletier]
#233992
02/24/09 04:01 PM
02/24/09 04:01 PM
Posts: 2,386 White Plains, NY
VCODE
White Plains, NY
Dave, Check your mail, it's full
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: DPelletier]
#233994
02/24/09 04:31 PM
02/24/09 04:31 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Well from what I can gather; - all '60 - '70 8 3/4" B body rears share the same dimensions BUT the brake lines go from '66 - '69 and then '70 has a different listing. I'll first measure the rearend to ensure it is a B body rear and then it looks like I'll need to order the earlier (QRB45) rather than the 1970 set (QRB74) Thanks again to everyone for the help. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#233995
02/24/09 05:24 PM
02/24/09 05:24 PM
JohnRR
Personally I would order the 70 set and move the vent to the correct location , I can't remember if the bracket for the flex line is bolted to the body or WELDED and if it's WELDED the early set may not line up correctly .
