brake lines 8 3/4 rear
#233970
02/23/09 05:16 PM
02/23/09 05:16 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Did 8 3/4" rear ends come with more than one location for the distribution block? The brake lines I bought from Y/O won't work: the RS one is too long and the PS one is too short as if the distribution block is in the wrong place. Any ideas? Cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: brake lines 8 3/4 rear
[Re: DPelletier]
#233971
02/23/09 05:50 PM
02/23/09 05:50 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Any ideas?
Cheers, Dave
Yes , I know A bodies have a different location for the block , changed around 69 ???
Sounds like you don't have the original housing in your car ?
[Re: JohnRR]
#233972
02/23/09 05:58 PM
02/23/09 05:58 PM
DPelletier
Thanks John; that's what I'm afraid of. There really isn't any way to tell for sure. I thought it was the original housing but who knows? OTOH, I can't begin to tell you all the repop or jobber "stuff" I've purchased that bears no resemlance to the proper parts....just not sure which is the case here. What I should do is probably check the listings for early B body 8 3/4 cars to see if they got different lines. Thanks Dave
1974 'Cuda
[Re: DPelletier]
#233973
02/23/09 06:11 PM
02/23/09 06:11 PM
JohnRR
U.S.S.A.
FYI , the early B body rears are narrower than 68-70 .
[Re: Mr_fixit]
#233978
02/23/09 08:05 PM
02/23/09 08:05 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
How "OFF" are they. I had to slightly bend the lines I got from Year One so they would fit.
[Re: stumpy]
#233981
02/23/09 09:40 PM
02/23/09 09:40 PM
DPelletier
Why not just measure the length you need and go to the local parts store and buy them?
Because they have about 6 bends each in them that would be difficult to duplicate; especially the radius curve over the pumpkin.
1974 'Cuda
[Re: burdar]
#233983
02/23/09 09:44 PM
02/23/09 09:44 PM
DPelletier
No, they are 2" too short/long respectively
1974 'Cuda
[Re: DPelletier]
#233988
02/24/09 12:38 AM
02/24/09 12:38 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Dave.....I have 3 '71 8 3/4" rears out of Challengers here....all three measure 17 3/8" from the inside flange of the left tube to the c/l of the vent bolt that holds down the tee. Two of these rears are still in the original cars and the other is out of my "Pink Turd" race car. I guess having 3 '71 Chally's in my shop is OK eh? Richard
