Originally Posted By n20mstr
Honestly I think the opening is too big. I would make some kind of reverse lip inside the scoop at the bottom edge. Maybe 1.5" so you don't get that turbulent air off the hood surface . It will give you "clean" air.
Yeah, I'm sure I can fit some type of scoop "stuffer" to see if blocking off the lower part of the entrance changes things in any way.
FWIW, I think (hope?) the car will be knocking on the 130 MPH door in the 1/4 w/ the updated engine combo.
