Re: 63 max wedge question [Re: ozymaxwedge] #2343558
07/26/17 10:17 AM
07/26/17 10:17 AM
A727Tflite Offline
A727Tflite  Offline
Yes- you are correct - built in October 1962.
Re: 63 max wedge question [Re: ozymaxwedge] #2350416
08/08/17 12:19 AM
08/08/17 12:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By ozymaxwedge
Originally Posted By 383man
Under Engine all Max Wedge cars have a 9 which means Super Stock eng. Under CR which means comp ratio if it has a 9 then its a 13.5 comp eng. If its the 11.0 comp eng then that space is blank.Ron
My car has NO 9 under CR and nothing under Alum but I have photos of it 1963 with Alum and SS II engine shruggy
Nothing under CR means its the low comp 11.0 eng. Didn't you say the aluminum front end was added ? They only built 40 aluminum front end Plymouths. The other 10 went in parts and were only sold as the complete set. So if you bought and added the aluminum front end it was not built with it so it would most likely be blank under aluminum. Ron
