Re: Hot Rod Drag Week 2017: The Experience.
[Re: MoparBilly]
#2369208
09/12/17 02:30 AM
09/12/17 02:30 AM
Posts: 2,255 IL
furious70
IL
he sprayed fuel out the back in the last couple min.
Billy ran 9.65 I think gremy 9.85 ruster 10.0x charger 11.xx and smoke
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: MoparBilly]
#2369363
09/12/17 01:03 PM
09/12/17 01:03 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I have to think they were looking for more(a lot more??) out of the Gemlin.
580 cubes, ported 440-1's, roller cam, tunnel ram.
[Re: MoparBilly]
#2369379
09/12/17 01:24 PM
09/12/17 01:24 PM
Posts: 2,255 IL
furious70
IL
he only got 1 shot right at the end of the day. don't know the back story but they rolled to the lanes late. Ruster took 2 passes, charger tried to but was leaking the first time. Valiant and gremy were 1 and done. Gremy looked ok, nothing obv wrong with the pass.
[Re: MoparBilly]
#2369382
09/12/17 01:28 PM
09/12/17 01:28 PM
fast68plymouth
So. Burlington, Vt.
I was watching the replay of the live feed last night..... It made a run in the first session..... I thought it was like a 9.79.
[Re: MoparBilly]
#2369387
09/12/17 01:35 PM
09/12/17 01:35 PM
Posts: 2,255 IL
furious70
IL
wow, somehow I missed that jumping 5seconds at a time thru the cars I didn't have time for :P
[Re: MoparBilly]
#2369393
09/12/17 01:43 PM
09/12/17 01:43 PM
Posts: 10,021 MN
JERICOGTX
MN
We had clutch issues. Bottom line, do not bring a untested car to Drag Week.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2369466
09/12/17 03:43 PM
09/12/17 03:43 PM
Posts: 2,255 IL
furious70
IL
We had clutch issues. Bottom line, do not bring a untested car to Drag Week. Are you guys out then?
[Re: MoparBilly]
#2369468
09/12/17 03:48 PM
09/12/17 03:48 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
The purple '70 cuda (Randy Heinselman) and the green '71 Demon (Paul Cornman) running Super Street Big Block N/A stepped up this year...both running 9.30s N/A! They are 1 and 2 in that class after the first day. Anyone know what combos these guys are running?
[Re: MoparBilly]
#2369566
09/12/17 06:35 PM
09/12/17 06:35 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Randy has an aluminum Hemi but indont know how big, it sure picked up this year.
Paul's car is supposed to be in small block. We talked to him today and he said they are supposed to fix the class listing. He moved to a Brett Miller w9 combo this year.
68 Barracuda Formula S 340
[Re: MoparBilly]
#2369591
09/12/17 07:06 PM
09/12/17 07:06 PM
fast68plymouth
So. Burlington, Vt.
Is there some sort of cube limit to still be able to run as a "small block"?
[Re: MoparBilly]
#2369594
09/12/17 07:11 PM
09/12/17 07:11 PM
Posts: 860 lancaster,california
johnnycuda
I think Randy's motor is a 522, I talked to him a few times the last month or so, I think the max on small block cubes is 440".
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: furious70]
#2369727
09/12/17 11:04 PM
09/12/17 11:04 PM
Posts: 1,290 Tucson AZ,
MadMopars
Tucson AZ,
We had clutch issues. Bottom line, do not bring a untested car to Drag Week. Are you guys out then? Didn't see Joel or Darren make a pass today. Day two results show them "Out". What a bummer. That said, day two brings the total number of "Outs" to 37 and puts the Quick 32 bump spot in the 10.90's. Drag Week has no mercy.
[Re: Dragula]
#2369756
09/12/17 11:28 PM
09/12/17 11:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The purple AAR Cuda just became my favorite running 9.30's NA super street followed by the 64 0r 65 Plymouth that ran an 8.80 NA!
Wow! Go Mopar!
What tires for super street? ALL cars on the track are suppose to be on DR or slicks.. most are on drag radials
[Re: MoparBilly]
#2369840
09/13/17 01:25 AM
09/13/17 01:25 AM
Posts: 2,255 IL
furious70
IL
Billy 9.46? Dale 9.43 ruster 9.97 sounded like it was breaking up? Farone 7.48 but down 20mph and is now hurt blasko went 7.71 I think after a crazy sideways pass
[Re: MoparBilly]
#2370047
09/13/17 01:54 PM
09/13/17 01:54 PM
Posts: 1,699 central il.
second 70
central il.
They were both smiling.
[Re: MoparBilly]
#2370061
09/13/17 02:11 PM
09/13/17 02:11 PM
fast68plymouth
So. Burlington, Vt.
I just finished watching the day 1 replay last night.
You could clearly hear Billy's car on his run( other car wasn't in the frame)...... Sounded real strong.
The Gremlin just seemed soft out of the hole.
I'll start in on day 2 tonite.
