Re: Air deflector inside hood scoop good idea w/ air filter?
[Re: ZIPPY]
#2335311
07/11/17 01:50 PM
07/11/17 01:50 PM
BradH
Hmm, I just don't know. Wonder if the DP racers are doing anything like that. One big difference is that they're EFI, which the late Monte Smith said was much less sensitive to airflow over the top of the entry.
[Re: BradH]
#2335314
07/11/17 01:56 PM
07/11/17 01:56 PM
Posts: 13,401 Marion, South Carolina [><]
an8sec70cuda
I always thought a deflector like you're thinking was more important without an air filter. The filter itself does a good bit of "turbulence straightening". The "deflector" pics you posted above are what I see on dirt track cars where they're just trying to keep mud from getting caked up on the air filter.
[Re: BradH]
#2335330
07/11/17 02:24 PM
07/11/17 02:24 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
It depends on the diameter and how tall the air filter is, doesn't it All the air has to go through the filter no matter what the throttle position is, correct? I wouldn't try fixing it until I knew is was broken
[Re: BradH]
#2335354
07/11/17 03:25 PM
07/11/17 03:25 PM
Posts: 4,584 Motor City
6PKRTSE
Motor City
With the Drag Pak'd T/A scoop on my Challenger being so big, it occurred to me that I might want to do something to keep the air entering the scoop from "slamming" into the air filter and/or causing buffeting or other airflow disturbances that could impact the carb's operation.
I found some different styles of air deflectors, a couple of which are shown below, that I might be able to adapt to the plate that seals the carb to the hood and might help w/ what I'm concerned about.
Does anyone else think this could be something worth testing out when my junk's finally back at the track? Thanks - Brad BradH? I have been thinking about running this hood & scoop on my 70 Challenger if I don't go with the shaker hood. Could you get me some measurements of the location, height, wide & length of the opening for the scoop? I am wondering if it will even clear my tunnel Ram with 2 Dominators on my Hemi or not? Thanks.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2335382
07/11/17 04:06 PM
07/11/17 04:06 PM
BradH
With the Drag Pak'd T/A scoop on my Challenger being so big... BradH? I have been thinking about running this hood & scoop on my 70 Challenger if I don't go with the shaker hood. Could you get me some measurements of the location, height, wide & length of the opening for the scoop? I am wondering if it will even clear my tunnel Ram with 2 Dominators on my Hemi or not? Thanks. My hood is a one-off done by a local (to me) fiberglass body person. It started out as an older reproduction T/A hood, then I decided I wanted about 1.5" additional clearance and my "glass guy" modified the original hood & scoop per my guidelines. The closest thing I've seen available as any type of production item is VFN's 5" T/A scoop added to their standard Challenger flat hood. A couple of people on here (either currently or in the past) have that hood & scoop combination, including the car in the pic below.
[Re: BradH]
#2335387
07/11/17 04:13 PM
07/11/17 04:13 PM
6PKRTSE
Motor City
Okay, thanks. Yeah, the VFN's 5" T/A scoop hood is what I was thinking your hood was & will probably be the hood I may order?
[Re: BradH]
#2335519
07/11/17 09:23 PM
07/11/17 09:23 PM
Posts: 4,212 New York
polyspheric
New York
WRT "much less sensitive to airflow over the top of the entry"
True, that. An EFI entry doesn't have the extremely sensitive air bleeds in the air horn, and no booster or venturi responsible for the controlling vacuum signal.
If the A/C interior volume (diameter inside the filter element X height) is big enough like 14" X 6", the air will be slowed & straightened passing through the filter, and IMHO no mods to the scoop are needed. There's no such thing as a too-big filter can or scoop interior (unless it significantly increases drag). The ideal volume is tunnel ram plenum size. Look at the Harwood stuff.
Relevant and not mentioned: the scoop's open area is sized for the highest MPH the car will see, be it 1/8", 1/4 or Bonneville, with highest MPH needing the smallest entry. A tractor pull needs a wood chipper entry (big power X low MPH = large scoop), a 300 MPH LSR needs a mailbox (big power X high MPH = small scoop). The Chrysler factory "Baughman" pro stock scoop is a lot smaller than you would expect. In real world terms, a hot street car that may never seen 125 MPH in anger needs a larger scoop than the same engine in a 1/4 mile car.
Boffin Emeritus
[Re: BradH]
#2335674
07/12/17 01:15 AM
07/12/17 01:15 AM
Posts: 4,699 On the parachute mount
n20mstr
Honestly I think the opening is too big. I would make some kind of reverse lip inside the scoop at the bottom edge. Maybe 1.5" so you don't get that turbulent air off the hood surface . It will give you "clean" air.
....BAD A$$ STREET CAR.....
[Re: racerx]
#2335869
07/12/17 12:53 PM
07/12/17 12:53 PM
6PKRTSE
Motor City
I have this vfn hood I can get measurement if you need them. RacerX, If you could get me those dimensions whenever you get a chance that would be great. No rush. Thanks.
[Re: 6PKRTSE]
#2336320
07/13/17 01:22 AM
07/13/17 01:22 AM
Posts: 4,076 Mo.
racerx
Mo.
I have this vfn hood I can get measurement if you need them. RacerX, If you could get me those dimensions whenever you get a chance that would be great. No rush. Thanks. Will do.
[Re: racerx]
#2337061
07/14/17 08:43 PM
07/14/17 08:43 PM
BradH
I might be able to adapt to the plate that seals the carb to the hood. Have any pics of said plate that seals the hood? I can probably dig up something. The last one was made of a luan panel from Home Despot, with a cutout in the center where I attached the base of a 14" air cleaner so it fit the carb nicely. Then I glued the fire-retardant (resistant?) foam that Moroso includes w/ their air pan kits (can be bought separately, too) around the perimeter. The closed hood held it down because I did multiple rounds of test-fitting to keep adding layers of the foam until the fit was "just right" with the hood down. It wasn't pretty, but the car picked up .1 ET and 1+ MPH vs. the same scoop w/o the carb sealed to the hood. Also, the old one was a good bit bigger than the new hood requires (different brand hood and the opening wasn't sized like a real T/A hood) and it was really obvious when you put your hand on the top of the hood after the car was running where the wood acted as a heat barrier vs the temp of the hood exposed directly to engine heat.
[Re: n20mstr]
#2337063
07/14/17 08:47 PM
07/14/17 08:47 PM
BradH
Honestly I think the opening is too big. I would make some kind of reverse lip inside the scoop at the bottom edge. Maybe 1.5" so you don't get that turbulent air off the hood surface . It will give you "clean" air. Yeah, I'm sure I can fit some type of scoop "stuffer" to see if blocking off the lower part of the entrance changes things in any way. FWIW, I think (hope?) the car will be knocking on the 130 MPH door in the 1/4 w/ the updated engine combo.
