Re: AndyF Motorplate/alt questions
[Re: HOTMOPR]
#2335320
07/11/17 02:04 PM
07/11/17 02:04 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
It's the same physical size just a higher amperage.. I checked that first
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: AndyF]
#2335323
07/11/17 02:09 PM
07/11/17 02:09 PM
HOTMOPR
Oakville, Wa
That alternator is too big to fit. Look at the alternator in my picture, it is much smaller. it's the same alternator just not black and have the upper mount shaved. Only difference is mine is 100 amp.
[Re: a493demon]
#2335367
07/11/17 03:46 PM
07/11/17 03:46 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I have the DMI bracket . But I got the plate that didn't have the cut out so I cut it myself. Same here but I had to cut down my bracket slightly due to it hitting my tubular K frame (Not the factory K frame).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2335550
07/11/17 10:18 PM
07/11/17 10:18 PM
dartman366
Mt. Vernon, Ohio
when I went to fit up my east coast mini there was no way it was going to fit in the little tiny space by the crank trigger, it hit every where, ended getting the ultra mini and was able to get it where I wanted it then came the mount top mount I drilled the lower bar or the AR plate that had the scallops and tapped it 3/8-16 and made a adjuster bar that I mounted to the side of the frame works great plenty of adjustment, if I can get a chance I will take a pic of it and try to get it posted on here.
[Re: dartman366]
#2335571
07/11/17 10:44 PM
07/11/17 10:44 PM
dartman366
Mt. Vernon, Ohio
here is a pic of the lower mount, you cannot see the upper part but it is just bolted to the bottom of the plate and spaced to align to the drive mandrel pulley.
[Re: HOTMOPR]
#2336201
07/12/17 10:38 PM
07/12/17 10:38 PM
HOTMOPR
Oakville, Wa
I got it to clear so far. Moved the braket up to the next hole, The upper bolt now goes through the web opening so I made a 1"x.25 aluminum washer for support. The adjuster braket will come off tabs on the frame rail.
Thanks for your guys inputs. MOPARS TO THE FRONT
[Re: HOTMOPR]
#2341397
07/22/17 11:07 AM
07/22/17 11:07 AM
Posts: 368 michigan
turbo toad
michigan
Al or any other members do you have a part number on the alt you guys are using on the dragster I'm getting ready to start final assembly next week and still need the smallest alt I can find with atleast 100 amps of current.
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: HOTMOPR]
#2341424
07/22/17 12:26 PM
07/22/17 12:26 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Thanks for your guys inputs. MOPARS TO THE FRONT Can you make a disc the size of the hole to support the bolt and slot it to fit the bolt size?Just an idea to make it stronger.
