Re: Weird MoPar interchangability.....
[Re: migsBIG]
#23496
06/22/11 02:48 AM
06/22/11 02:48 AM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I have that book, and it's not nearly as informative nor as comprehensive as MOPARTS! All good info here guys, keep it coming!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: Fury Fan]
#23499
03/25/13 02:25 PM
03/25/13 02:25 PM
Pretty well ALL of the consoles in B and C bodies of each year are the same...
Since you capitalized ALL, a couple exceptions are: 70 Fury same as B; 70 Chrysler is different, 65 Chrysler has different top plates from B and Fury, 65 Monaco 500 extends 2-3" into the rear bench seat (which is unique), 66 Charger is full-length, 1-year-only.
Probably a few other years I overlooked.
C body consoles had a rear chrome plate that had a cigar lighter mounted in it, and the horizontal vanes were opened up so you can have elegant floor lighting in the rear of your b body console, Just switch the plate out and run some wiring.
#23500
03/25/13 02:41 PM
03/25/13 02:41 PM
Electric trunk releases fit almost any mopar. Just run wire, add some release buttons anywhere you want and bolt the electric unit on in place of your old trunk release.
